Sparkle2009
- 7
In a youngs double slit experiment,if the slit widths are in the ratio 1:2,the ratio of intensities at maxima and minima will be ?
The Young's Double Slit experiment is a classic physics experiment that demonstrates the wave-like nature of light. It involves passing light through two parallel slits and observing the interference pattern that is created on a screen placed behind the slits.
The intensities at maxima and minima refer to the bright and dark fringes respectively in the interference pattern created by Young's Double Slit experiment. The intensity at the maxima is where the two diffracted waves from the two slits are in phase and reinforce each other, resulting in a bright fringe. On the other hand, the intensity at the minima is where the two waves are out of phase and cancel each other out, resulting in a dark fringe.
The intensities at maxima and minima are inversely proportional to the distance between the slits. This means that as the distance between the slits increases, the intensity at the maxima decreases and the intensity at the minima increases. This relationship is known as the inverse square law.
The intensities at maxima and minima can be affected by the wavelength of the light used, the distance between the slits, and the distance between the slits and the screen. Any changes in these factors can result in a different interference pattern and therefore, affect the intensities at maxima and minima.
The Young's Double Slit experiment is not only a fundamental demonstration of the wave-like nature of light, but it also has practical applications in various fields such as optics, astronomy, and quantum mechanics. It has also paved the way for further research on the behavior of light and its impact on our understanding of the universe.
