Young's Modulus of aquarium
  • Thread starter houseguest
A large 3.00×10^4 L aquarium is supported by four wood posts (Douglas fir) at the corners. Each post has a square 3.80 cm x 3.80 cm cross section and is 80.0 cm tall.
By how much is each post compressed by the weight of the aquarium?
deltaL = F*L_0/(Y*A)
Y (for Douglas fir) = 1 * 10^10 N/m^2
This seems very straight forward, I just need to determine F.
F= ma = m(aquarium)g
but, what is the mass of a 3.00×10^4 L aquarium?
once I determine that, I figure it'll just be:
deltaL = ( m * 9.8 * .8)/(.144 * 10^10) meters
=> 5.44*10^10*m meters
How do I find m ??
Thanks for the help!
Answers and Replies
Shooting Star
1,977
Since nothing else is given, consider the significant portion of the weight of the aquarium to be due to just water.
So I took the mass of water to be 1Kg per liter.
So the m = 3 * 10^4
Then the equation comes out as:
deltaL = ( 3 * 10^4 * 9.8 * .8)/(.144 * 10^10) meters
= 1.63 * 10^-4 m
But I am told this is the incorrect answer.
Any help???
Thanks!
Mapes
What's the total area on which the weight acts, in m2?
4*.144 = .576 m^2
but, isn't it asking the deltaL for an individual post?
I thought that I might have to divide the force by 4, but that answer was also incorrect.
Thanks
Mapes
Isn't it 0.0144 m2? Also, it's the pressure (stress) that causes the strain; you need to find the pressure on a single leg before you can calculate the strain. The way you originally had it, the compression distance was independent of the number of legs.
EDIT: Right, 0.00144 m2
Hang on, I see the mistake I made earlier: 3.8 cm x 3.8 cm = .038m x .038m = .00144 m^2 (thanks btw), but wouldn't then total area then be 4 * .00144 = .00576 m^2 ?
Then the pressure would be 3 * 10^4 * 9.8 / .00576.
Then plug in that pressure for F in
Is that right?
Although, it retrospect this can't be right since
deltaL = ( (3 * 10^4 * 9.8) / .00576 * .8) / (.00144 * 10^10) meters
= 2.84 m
and that is way to large to be realistic
Mapes
You divided by area twice.
oh yeah, duh.
Thank you so much for your help!!! Seriously.
Related Threads on Young's Modulus of aquarium
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
