Yukawa Potential
  1. Feb 23, 2009 #1
    I would appreciate an explanation of Yukawa potential
  3. Feb 23, 2009 #2
    Tom Mattson
    Staff Emeritus
    The Yukawa potential is the potential that arises from a massive scalar field. It is:
    [tex]V(r)=-k\frac{exp(-\mu r)}{r}[/tex]
    where [itex]k>0[/itex] and [itex]\mu[/itex] is the mass of the mediating field.
    Note that:
    1.) It is attractive (that is, [itex]F=-\frac{\partial V}{\partial r}[/itex] is negative).
    2.) It reduces to the Coulomb potential for [itex]\mu =0[/itex].
  4. Feb 23, 2009 #3
    jtbell
    Staff: Mentor
  5. Feb 23, 2009 #4
    The Yukawa Potential can be roughly thought of as a generalization of an inverse-square force potential that takes into account a massive mediator or force. This would mean that instead of massless photons exchanging the force, as is the case with electromagnetism, some other particle with mass exchanges the force between two particles.
  6. Feb 24, 2009 #5
    In the Wikipedia link:
    http://en.wikipedia.org/wiki/Yukawa_potential
    it says that the Fourier transformation of the Yukawa potential is the amplitude for two fermions to scatter. But the Fourier transform ignores 4-momentum and only has 3-momentum. The amplitude to scatter should depend on a 4-momentum squared, and not 3-momentum. So how is this reconciled?
  7. Feb 24, 2009 #6
    There is a problem in Jackson's E&M book which asks you to derive the charge distribution corresponding to this potential. I could never quite get it right.
  8. Feb 25, 2009 #7
    may i know the page no and the problem to be solved in Jackson Book of E and M
  9. Feb 25, 2009 #8
    I'm not as familiar with relativistic QM as I would like to be, but it seems like the given formula actually does depend on the four momentum. The k in transform corresponds to the three spatial components of the four-momentum while the m corresponds to mass, which in turn depends on the time component of the four-momentum. Why the fourth component of the four-momentum is left out of the Fourier Transform, on the other hand, is unfamiliar to me.
    It is known that, from the definition of V (in a static field) and the first of Maxwell's equations that:
    [itex]\nabla\cdot\vec{E}=-\nabla ^2V=\frac{\rho}{\epsilon _0}[/itex]
    So that to find the charge density, one must simply take the negative Laplacian of the potential. This will work every where except for the origin, where you have to apply gauss's law and gauss's vector calculus equation to find the charge. I found:
    [itex]\rho (r)=4\pi g^2\epsilon _0 \delta (r)-g^2m^2\frac{e^{-mr}}{r}[/itex]
  10. Feb 25, 2009 #9
    clem
    The simplified version of the Yukawa derivation takes place in the barycentric system where the energy component of the 4-momentum transfer vanishes. Then the 3D Fourier T can be made.
  11. Feb 25, 2009 #10
    Does barycentric system mean center of mass frame between the two fermions? Does this mean that the Yukawa potential is only valid in a center of mass frame, since you break Lorentz invariance by choosing a specific frame?
  12. Mar 25, 2009 #11
    May I come to know about the barycentric systems
    I have listened the word for the first time and I am curious to know about it because you have mentioned that it reduces the 4 momentum to 3- momentum
  13. Mar 25, 2009 #12
    clem
    The "barycentric system" is the Lorentz system in which the total momentum equals zero. It is usually loosely called (even by me) the center of mass (cm) system, even though the term "center of mass" has no clear meaning in relativity. The Yukawa potential is usually derived for two nucleons. Then the energy component of the 4-momentum transfer vanishes in the cm system because the two individual energies are equal. It is valid only in the cm system, where most calculations are made anyway. The simple Yukawa potential is used mainly in nonrelativitic calculations , because other effects become important at higher energies. The Yukawa potential by itself is now useful only for simple order of magnitude estimates because the full N-N interaction is more complicated. It does describe the long range part of the N-N potential.
  14. Mar 26, 2009 #13
    thanks a lot for such an eloborative reply
    butit has increased my curicity
    will you help me to tell what are the other factors responsible for N-N interactions
  15. Mar 26, 2009 #14
    clem
    You really need to go to a book on strong interactions now.
  16. May 13, 2009 #15
    I know it very well
    that I am not known to all these things thats why I sk you for recommending me a book
    (a specific book)
    because I can have book from a library or may have it on rent before purchasing it
Similar Discussions: Yukawa Potential
  1. Yukawa Interaction (Replies: 0)
  2. 1)yukawa Potential (Replies: 2)
Loading...
