How Does a Zener Diode Stabilize Voltage in a Circuit?
In summary: This allows for the amplification of the input signal without any interference from the power supply. In summary, the common emitter transistor circuit is used to amplify a signal and works by establishing a reference voltage through grounding and providing the necessary bias voltage through the emitter.
clavin
well first i saw this solution of a zener diode problem on net
A 5.0v stabilised power supply is required from a 12v d.c. input source. The maximum power rating of the Zener diode is 2W. Load resistance = 1 kiloohm Using the circuit above calculate:
circuit : http://www.electronics-tutorials.ws/diode/diode24.gif
b) The value of the series resistor, RS
12-5/(400mA) = 17.5 ohm
so is the above solution right
cuz i think it should be
12-5/(405mA)
second can somebody explain me a bit about ce transistor circuits
first a little bit about what it does
and secondly how does the circuit works
like why there's grounding
and also i saw that the emitter is connected to the positive terminal of one battery and the negative terminal of other
so in that branch how will the current flow
from postitve terminal of one batter to the negative of the other without passing through emitter? or in some other way
?Yes, the solution is correct. Common emitter transistor circuits are used to amplify a signal. The circuit works by taking an input signal (typically through the base of the transistor) and amplifying it before it is output from the collector of the transistor. The ground of the circuit is connected to the negative terminal of the power supply in order to establish a reference voltage against which the input and output signals can be measured. The emitter of the transistor is connected to the positive terminal of one battery and the negative terminal of the other in order to provide the necessary bias voltage for the transistor. The current flows from the positive terminal of the one battery, through the collector-emitter junction of the transistor, and then to the negative terminal of the other battery.
1. What is the function of a Zener diode and how does it work?
A Zener diode is a type of semiconductor device that is specifically designed to operate in the reverse breakdown region of its current-voltage (IV) characteristic curve. Its main function is to regulate voltage by maintaining a constant voltage level despite changes in the input voltage. This is achieved through a process called Zener breakdown, where the diode allows current to flow in the reverse direction once a certain voltage threshold is reached.
2. What are the main applications of Zener diodes?
Zener diodes are widely used in electronic circuits for voltage regulation, voltage reference, and protection against overvoltage. They are commonly found in power supplies, voltage regulators, surge protectors, and voltage clamping circuits.
3. How is a transistor different from a Zener diode?
A transistor is a three-terminal semiconductor device that can amplify and switch electronic signals. Unlike a Zener diode, which is mainly used for voltage regulation, a transistor can perform a variety of functions including amplification, switching, and modulation.
4. What are the different types of transistors and their uses?
The two main types of transistors are bipolar junction transistors (BJTs) and metal-oxide-semiconductor field-effect transistors (MOSFETs). BJTs are commonly used in low-power applications such as amplifiers, while MOSFETs are used in high-power applications such as power supplies and motor control.
5. How do transistors contribute to the development of modern technology?
Transistors are a crucial component in modern technology, as they are used in almost all electronic devices including computers, smartphones, and televisions. They allow for miniaturization of electronic circuits, improved efficiency, and faster processing speeds. The development of transistor technology has greatly advanced the field of electronics and has revolutionized the way we live and work.
  • Electrical Engineering
