Can the Zeno Paradox be Resolved Through Infinite Divisions?
In summary: And you're so proud of it, too.In summary, the conversation discusses a possible solution to the Zeno Paradox, where the concept of a race between two objects at different speeds is simplified. The speaker suggests dividing the distance traveled into an infinite number of segments and adding them together, resulting in D/(infinite) * infinite = D. However, the other person raises questions about the validity of this solution and points out that infinity is not well-defined. The conversation also delves into the limitations of mathematical divisions and the concept of infinity. Ultimately, the conversation reveals that the true solution to the paradox is to eliminate the concept of infinity.
  • #36
Hurkyl said:
Just for fun...
ithat there would always be a halfway point the must first be traveled before the Line could EVER be reached – and logically EVER becomes NEVER.​
would you care to take a stab at justifying this passage?
what is so hard about that?
Zeno uses our logic of motion and space to define a halfway point that will always be between our object and the finish line – if there is always something between it and the finish how can the finish ever be reached. As Zeno says this shows it cannot and will never be reached – he uses our rules of space and motion to produces absurd results, his paradox still stands.
These forums expect a statement like “Zeno's argument is an invalid argument” to be supported by more than a “Straw man” debate - you have an obligation to present obvious points Zeno would raise not just pretend he would stand mute.
Peano arithmetic is 19th century math on number theory – where is your justification to extending that to real distances that you assume can be traversed by things in motion. If you have only assumed that to be true then your just begging the question.
Do you really think Zeno would stand mute as if made of straw if we use such flawed logic?
If you don’t know what "begging the question" is, Too Bad open a book on logic. If you want to claim Zeno’s paradox’s as false arguments you need to use formal logic to do so.
If you really think the experts already motioned are wrong, name the peer reviewed papers that show that and use them to correct the Wiki Information to agree with your opinions. Keep us updated on your progress in that effort.
Otherwise just because I agree with the science of motion is no reason to accept your logic or assumptions like "instantaneous velocity" over Wikipedia information that real experts say these paradoxes have not been formally rejected.
Mathematics news on Phys.org
  • #37
I'm surprised you put such faith in Wikipedia.
  • #38
That is not a valid argument. Instead of using a chain of deductive reasoning to justify your conclusion, you are appealing to your ignorance about how the conclusion could fail.
This error is particularly egregious because you are not ignorant about how the conclusion could fail -- you are perfectly aware of the traditional calculus-based "sum of series" argument. (Which, according to Wikipedia, was already known as far back as Aristotle).
An "obvious" point Zeno would raise is
each individual subgoal takes time, and so infinitely many subgoals must take infinitely much time​
which I've already presented and invalidated in this thread. The only other "obvious" point I can imagine Zeno bringing up is
Each event in a ordered chain of events must either be the first event, or have an event immediately preceding it. Similarly for last and succeeding.​
which, incidentally, is tantamount to assuming a priori that infinite divisibility is impossible. But that's easily invalidated by pointing out there's no justification given for such an assumption. In fact, physics allows the order type chain of events can be any suborder of R.
But -- you've already rejected this method to refuting Zeno through a bit of sophistry1: you've pretended that such an argument is merely providing the other half of Zeno's contradiction rather than demonstrating an error in his reasoning. I pointed this out earlier, but you didn't bother to defend or retract your assertion. I didn't press the issue because I thought it interesting to take up another line of attack. But since you are pressing the issue, discussion cannot proceed until you address my objection.
1: Pun intended: I mean this in the pejorative sense.
As for the other line of attack -- I had assumed you were aware of some of the basic relationships between syntax and semantics: suppose we are considering whether or not a proposition P can be proven by deductive logic. One necessary condition is that P must be true in every semantic interpretation of our language -- no matter how strange or convoluted it might be. Contrapositively, if any interpretation can be constructed where P is false, then P cannot be proven deductively.
On the assumption that Peano arithmetic is consistent, I have provided an interpretation that serves as a counterexample. Furthermore, I assert that it's a 'reasonable' counterexample, on the grounds it's essentially the same as (a particular example of) the way we normally interpret the notions of 'space', 'time', and 'motion', except I have replaced the continuum R with the rational numbers.
Since your argument is informal, it can never be truly refuted, because you can always surprise us at the last minute and say "Haha, this whole time I was really making the a priori assumption that motion is impossible, I just never bothered to explicitly state it!" (of course, at this point we'd all dismiss your argument as vacuous) But I can (and have) refuted the particular argument you have put forth.
  • #39
That is impossible – I was clear that Zeno was presenting a argument based on the a priori assumption of motion to build an absurd result. You cannot possible be so dense as to miss that point.
If you seriously think that all philosophers agree with you, then site an authority in the field and have them see to that that Wikipedia is revised based on that authority to remove the statement:
However, some philosophers insist that the deeper metaphysical questions, as raised by Zeno's paradoxes, are not addressed by the calculus. That is, while calculus tells us where and when Achilles will overtake the Tortoise, philosophers do not see how calculus takes anything away from Zeno's reasoning that concludes that this event cannot take place in the first place. Most importantly, many philosophers do not see where, according to the calculus, Zeno's reasoning goes wrong …​
Absent that I’ll only be able to logically assume you are not really serious.
Your illogical logic resorting to insults disqualify you as useful as a mentor on this topic – so see you in another thread on another subject someday, but you and I are done in this one.
  • #40
Randall, you place relatively too much confidence in your authorities, and relatively too little confidence in your own ability to reason.
As someone who holds degrees in mathematics, physics, and philosophy, I hope you would consider that I agree with Hurkyl, for what it's worth. I believe that, for example, the rebuttal in post #35 is definitive.
If you truly wish to argue that Zeno's paradox is not resolved, then let us examine the article that is linked in the wikipedia web page:
http://philsci-archive.pitt.edu/archive/00002304/
I hope that anyone who has a moderate training in mathematics, logic, and philosophy will see that this paper only succeeds in supporting its premise in as much as it also trivializes Zeno's arguments. The author has a pompous attitude, and he callously makes claims of impossibility without any hint of a rigorous proof; it is a crackpot paper.
  • #41
If you believe I have insulted you, then you should use the 'report post' feature to make the other mentors (and the administration) aware of my behavior. Assuming you're serious, I'm not really sure what prompted your opinion -- was it the phrase 'appeal to ignorance'? That wasn't an insult: I am using it in its technical meaning describing a class of formal fallacies resembling that of justifying a position on the basis that one is unaware of evidence to the contrary.
Incidentally, there was another error I failed to point out:
He only demonstrates such a halfway point exists when the object is not yet at the finish line.
  • #42
Zenoman said:
The segments that the line is divided into. If we have a line of length D and we divide it into an infinite amount of sections then each section would be the width of D/(infinite)
Zenoman,
Here is something to think about from your original arguement:
I'd argue that since there are an infinite amount of points in a line segment, if you could divide a line segment into an infinite amount you wouldn't end up with points! And as Euclid said, a point is that which has no width. But you are saying it has a width of D/(infinite). How is this any different from (D+10)/(infinite)?
The problem really is you are trying to treat infinity as a number, and it is a concept, not a number.
  • #43
Also I have feel I have a much deeper understanding of the paradox due to Hurkyls and RandallB's lively debate! Keep it up guys!
  • General Math
  • Quantum Interpretations and Foundations
  • Other Physics Topics
