Homework Help: Zero vector and -v question
  1. Oct 1, 2012 #1
    If we give X = R2 the non-standard operations
    (x, y,) ⊕ (x' , y') = (x + x' - 1, y + y' +2) (vector addition)
    and
    k~(x, y) = (kx - k + 1, ky + 2k -2) (multiplication by scalars)
    then X is a real vector space.
    - What is the zero vector of X?
    - If v = (x, y) is in X then what is -v?
    2. Relevant equations
    3. The attempt at a solution
    So attempted to answer both these questions. For the first one if you make x and y = 0 then you are left with (-1, 2) so that is what I thought the zero vector of X was. For the second answer I did (-1)x(x,y) so I got -v = (-x+2, -y-4). Just wondering if someone could help me out here and confirm if these are correct.
    Thanks
  3. Oct 1, 2012 #2
    LCKurtz
    To get the zero vector (a,b) you need to have (x,y) ⊕ (a,b) = (x,y). Solve that for a and b.
  4. Oct 1, 2012 #3
    So therefore (a,b) = (0,0)? Also, is my answer for the second question correct?
  5. Oct 1, 2012 #4
    LCKurtz
    No. Show your work how you got (a,b). No point in worrying about your second question until you get the first one correct because you will need -v ⊕ v = 0 and you don't have 0 figured out yet.
  6. Oct 1, 2012 #5
    so then would it be (x,y,) ⊕ (a,b) = (x+a-1, y+b+2) then if (a,b) = (0,0) then = (x-1, y+2). Is that how it should be? Thanks for your help!
  7. Oct 1, 2012 #6
    LCKurtz
    I don't know where you are getting (0,0) from. You are trying to find the additive identity -- when you ⊕ it to a vector you get that vector back. The red tells you exactly what to do.
  8. Oct 1, 2012 #7
    Sorry lol im really confused. If (x,y) ⊕ (a,b) = (x,y) then (x+a, y+b) = (x,y).Is that how it should be?
  9. Oct 1, 2012 #8
    LCKurtz
    No. That isn't how you do ⊕. Do it correctly. Then figure out the a and b that make it work.
    On another note, one thing that may be confusing you is the fact the problem as calling what you seek the "zero vector", which you are thinking of as (0,0). But this is a different vector space, and ⊕ is not + and the "zero vector" would better be called the "additive identity". And it isn't (0,0). You can see that by taking (x,y)⊕(0,0) and seeing you don't get (x,y).
  10. Oct 1, 2012 #9
    Sorry I am really trying to understand this but I can't :(
    The ⊕ symbol is basically implying vector addition. So if you want me to do (x,y) ⊕ (a,b) = (x,y) it would basically be (x+a, y+b) = (x,y). Is that right?
    Sorry for not understanding but I am new to all this linear algebra stuff. Everything else is pretty easy.
  11. Oct 1, 2012 #10
    LCKurtz
    NO!! (x,y) ⊕ (a,b) is not (x+a, y+b). Your first post tells how to do ⊕. Look at your formula above. It is not standard vector addition. Use that formula.
  12. Oct 1, 2012 #11
    Oh okay, so like this:
    (x, y,) ⊕ (a , b) = (x + a - 1, y + b +2)
    then a = 1 - x and b = -2 - y?
  13. Oct 1, 2012 #12
    LCKurtz
    No. Do exactly what I suggested in post #2, which I have quoted above.
  14. Oct 1, 2012 #13
    Okay so this is what you quoted:
    To find the zero vector (a, b), I need to do this (x, y) ⊕ (a, b). So basically I am replacing (x', y') with (a, b) which would give me
    (x, y) ⊕ (a, b) = (x + a - 1, y + b - + 2)
    Like that?
  15. Oct 1, 2012 #14
    LCKurtz
    Man, you are making this way too difficult. What part of (x,y) ⊕ (a,b) = (x,y) don't you understand? It is an equation with two sides and an = sign. And you know how to calculate the left side but you keep ignoring the right side.
  16. Oct 1, 2012 #15
    So then (x + a - 1, y + b +2) = (x, y)?
  17. Oct 2, 2012 #16
    LCKurtz
    and so...?
  18. Oct 2, 2012 #17
    x + a - 1 = x
    a - 1 = 0
    y + b + 2 = y
    b + 2 = 0
    so (a-1, b+2) is the zero vector?
  19. Oct 2, 2012 #18
    LCKurtz
    Read my post #2 again. What does it say to do with the equation?
  20. Oct 2, 2012 #19
    Oh so a = 1 and b = -2 so (1, -2) is the zero vector?
  21. Oct 2, 2012 #20
    LCKurtz
    Now, you don't have to ask me that. I want you to check it yourself. If it is the additive identity then if you ⊕ it with any vector (c,d) you should get (c,d) back. That's what an additive identity does. Does (1,-2) do that?
  22. Oct 2, 2012 #21
    Ya so (c, d) ⊕ (1, -2) = (c + 1 - 1, d + -2 + 2) = (c, d). I get it now :) thanks. Now for the second part. So 0 + v = v or v+(-v) = 0. I know that the zero vector (is 1, -2) so:
    (x, y) + -(x, y) = (1, -2)
    like that?
  23. Oct 2, 2012 #22
    LCKurtz
    Start with -(x,y) = (a,b) unknown just like before. And use ⊕, not + in that equation.
  24. Oct 2, 2012 #23
    SO it would be:
    -(x, y) ⊕ (a, b) = 0
    (-x, -y) ⊕ (a, b) = 0
    (-x + a - 1, -y + b +2) = (1, -2)
    So
    -x + a - 1 = 1
    a = x + 2
    -y + b + 2 = -2
    b = y + 4
    So -v = (x + 2, y + 4)
  25. Oct 2, 2012 #24
    so is that correct?
  26. Oct 2, 2012 #25
    LCKurtz
    Again, you don't have to ask me that. Check that it does what it is supposed to like you did before for the additive identity.
