Zinc chloride as Lewis acid
Main Question or Discussion Point
Zinc chloride is Electrophilic and so acts as a Lewis acid.This characteristic is due to it's ability to accept electrons to it's 4 d orbital.My question is why it receives electrons to it's 4 d orbital when 4 p remain empty( according to Aufbau diagram)?Are there any other d block element capable of accepting electrons to 4 d orbital leaving 4 p and 5 s orbitals ?
Answers and Replies
TeethWhitener
911
Says who? This should be 3d.
edit: 4s, not 3d.
According to the configuration of zinc it is [Ar]3 d^ 10,4 s^2.As such there is no room for fresh electrons to enter 3 d .So the next option is 4 p. could you make this clear?
TeethWhitener
911
What is the electron configuration of zinc in ZnCl2? Hint: it’s not what you’ve written.
chemisttree
194
Beat me to it! 👍🏻
I am stuck here.Please help.
chemisttree
194
You have written the electronic configuration for neutral zinc. In the compound zinc chloride, is zinc neutral?
I agree that in Zn Cl 2 Zn is not neutral.It has donated electrons to chlorine forming Zn ion. I am appending a post from internet which mentions about 4 d orbital which I referred initially:-
The basic characteristics of a Lewis Acid is property of gaining electron
In ZnCl2 Electronic configuration of zinc is 3d ^10 so it has a tendency to accept electrons in its empty 4d orbitals so it act as Lewis acid
I hope this helps.
TeethWhitener
911
No, the 4d orbitals are way too high in energy to accept electrons. The zinc in ZnCl2 is Zn2+. If the electronic configuration of neutral zinc is [Ar]4s23d10 and in Zn2+ is [Ar]3d10, what orbital in Zn2+ do you think will accept electrons?
Thank you for your reply.As a Lewis acid it will accept extra electrons and I feel electrons will enter 4 p orbitals.I don't whether I am right.Please enlighten me.
TeethWhitener
911
Let’s try again: neutral zinc is [Ar]4s23d10 and Zn2+ is [Ar]3d10. If Zn2+ accepts an electron pair as a Lewis acid, which orbital will the electrons go into?
As I wrote to you earlier the electrons should enter the empty 4 p orbital.Am I right?
chemisttree
194
No you aren’t. From your Aufbau diagram, which electrons fill after 3d10?
According to aufbau diagram the next orbital to be filled is 4 p and then 5 s
TeethWhitener
911
Let’s try this the other way. If you start with neutral zinc [Ar]4s23d10 and you lose two electrons to get Zn2+ [Ar]3d10, which orbital became empty after the loss of the two electrons?
chemisttree
194
Right. So you agree that 4p is higher energy than 4s? Both are empty in Zn+2.
Still I am unable to know which orbital fresh electrons going to fill after 3 d in Zn+2
TeethWhitener
911
Start by answering my question in post 15.
According to your post 15 the 4 s orbital is empty after loss of two electrons
TeethWhitener
911
Ok so now read @chemisttree 's post 16. What is the lowest energy empty orbital in Zn2+?
According to post 16 of chemisttree lowest empty orbital is 4 s in Zn+2
TeethWhitener
911
Ok so according to Aufbau, which orbital in Zn2+ gets filled first?
So according to aubau diagram 4 p is going to be filled first
TeethWhitener
911
What is the Aufbau principle, in your own words?
chemisttree
194
I think Hari has it now. We should let this info stew for a while until Hari has the epiphany I know is coming. Anything further is just trolling...
Related Threads for: Zinc chloride as Lewis acid
  • Last Post
22K
  • Last Post
56K
  • Last Post
  • Last Post
10K
