Formation of Zinc Oxide: Can Metal Strip be Oxidized?
In summary, Zinc Oxide is used as a protective layer on iron in order to prevent further oxidation. When it is stored in an environment with oxygen, it will slowly turn into a white powder.
ryanuser
74
Hi
I am aware that Zinc Oxide (ZnO) is in the form of white powder. Can I leave a strip of Zinc in a room (at presence of Oxygen) so that it becomes oxidised therefore the same thing is resulted but in form of a metal strip instead of powder? Would the resulted strip become as oxidised as the powder? How long do I have to leave it in a room full of Oxygen?
Thanks
Chemistry news on Phys.org
During oxidation metallic zinc will become a white powder, that's chemistry for you :wink:
How long it will take is not easy to estimate. It won't be fast, zinc granules (often used in the lab) are stable enough that they can be kept just in a jar (that is regularly opened) for years.
Thanks Borek
Not 100% sure, but I can tell you that Zinc oxidises pretty quickly, faster than Iron. I don't think the whole strip will just completely break down very quickly, for the whole strip to become Zinc Oxide and form a salt, a lot of time may be needed. Zinc is used for galvanisation, because it oxidises really quickly, forming a protective Zinc Oxide layer.
Try consult people who specialise in chemistry if you are not satisfied with the information you have received so far.
This is actually a bit more complex. While you are right about it being covered with an oxide layer, it is used because it protects the iron below in a same way sacrificial anodes do - it corrodes first, leaving iron untouched.
Ingots of zinc metal as used in foundries are sometimes stored for long periods in poor conditions .
One noticeable effect is that the ingots become slimy to feel - like a bar of soap . Can only guess why that would be . Also the very attractive crystalline patterns found on surfaces of new ingots tend to degrade and become less well defined over time .
At higher temperatures in a melt of zinc metal or a high zinc alloy some zinc will boil off and form clouds of zinc oxide which thickly coat everything around with white powder if the correct melting process is not followed .
Likes Merlin3189
The zinc oxide reacts with the CO2 in the air to form a protective layer of zinc carbonate, which with the Zinc oxide layer hinders further oxidation.
That could be the slimy feel, but is responsible for the appearance of the degradation of the crystal structure.
On an iron surface there is a two fold protection:
1. barrier protection from further corrosion form the zinc oxide layer
2. sacrificial galvanic protection
I didn't feel the need to mention that, because it seemed pointless to go off-topic putting too much effort into describing the whole reason for Zn to be used in galvanisation. It also seemed pretty obvious. Thank you for your suggestion.
1. What is the chemical equation for the formation of zinc oxide from a metal strip?
The chemical equation for the formation of zinc oxide from a metal strip is 2Zn + O2 → 2ZnO. This reaction occurs when zinc atoms react with oxygen atoms in the air to form zinc oxide.
2. How does the oxidation of a metal strip occur?
The oxidation of a metal strip occurs when the metal atoms react with oxygen atoms in the air. This reaction results in the formation of a metal oxide, such as zinc oxide, on the surface of the metal strip. This process is also known as corrosion.
3. What factors can affect the formation of zinc oxide on a metal strip?
The formation of zinc oxide on a metal strip can be affected by several factors, including temperature, humidity, and the presence of other chemicals. Higher temperatures and humidity levels can increase the rate of oxidation, while the presence of certain chemicals, such as acids, can accelerate the process as well.
4. Is the formation of zinc oxide a reversible process?
No, the formation of zinc oxide is not a reversible process. Once the zinc atoms have reacted with oxygen to form zinc oxide, the process cannot be reversed. However, the zinc oxide can be reduced back to zinc metal through a separate chemical reaction.
5. What are some practical applications of zinc oxide formed from a metal strip?
Zinc oxide formed from a metal strip has many practical applications. It is commonly used as a white pigment in paints, as a coating on metals to prevent corrosion, and in the production of rubber and plastics. It also has medical applications, such as in the production of sunscreen and as an antibacterial agent in ointments and creams.
  • Chemistry
  • Chemistry
  • Materials and Chemical Engineering
