Manometer and Bourdon Gage
The elevation of the horizontal pipe is slightly above sea level. Water flows through a pipe that has been fitted with a manometer and a Bourdon gage. Use the readings of the manometer and Bourdon gage:
Calculate the pressure of water flowing through the pipe.
♦ We always start at a place in space where the pressure of the fluid is known.
Manometer At the center-line of the pipe but outside in the air about it; the pressure there is atmospheric pressure. Let that point be our first (known) pressure. The path now moves upward 142mm to the upper surface of the mercury. From there follow a hydrostatic path through the mercury (gage) to the center-line of the flow of water.
patm + 13,600 kg/m39.81 m/s2(0.284 m) -1,000 kg/m³9.81 m/s2(0.142 m) = 137.8 kPa
Bourdon Gage: This gage is connected to the side of the pipe at its center-line. Thus atmospheric pressure plus the gage reading (G.R.) will equal the pressure of the water inside the pipe.
patm + G.R. = pwater or 101.3 kPa + 38 kPa = 139 kPa
One pascal of pressure difference is very small. The Bourdon gage might be incorrect - it had to be calibrated. The water pressure should decrease in the direction of flow.
