| 3.00
Engineering Thermodynamics |
110 |
Work, Energy Discussion: BODY |
| 3.01
Work: BODY |
111 |
| 3.02
Mechanical Energy Equation |
112 |
Bilge Pump Work |
113 |
Buoy Lift I |
114 |
Buoy Lift II |
115 |
Champagne Cork Velocity |
116 |
Slap Shot |
117 |
Kids Clean the Garage |
118 |
Tank with a Movable Wall |
119 |
Harpy's Nest |
120 |
| 3.03
Work Considerations |
121 |
Work and Kinetic Energy: BODY |
Back Squat |
122 |
Rock Climb |
123 |
Work to Draw the Castle Bridge |
124 |
Elephant Weighs Teak |
125 |
Polaris Scale Model |
126 |
Choice of Worker: "A" or "B" ? |
127 |
Pushing a Crate Uphill |
128 |
Boy in a Wheelchair |
129 |
Egg-Drop Challenge |
130 |
Planet Gizmo |
131 |
| 3.04 Work as "on" or "by" |
132 |
Work, Potential Energy: BODY |
Optimized Work |
133 |
Drunk Driving Awareness |
134 |
Wreck at Batavia |
135 |
Rock Falls onto a Spring |
136 |
| 3.05
System: Selection and Isolation |
137 |
| 3.06
Forklift Events |
138 |
| 3.07
Energy Equation: BODY |
139 |
| 3.08 Internal Energy |
140 |
| 3.09
Compression Work |
141 |
| 3.10 Energy: SUBSTANCE |
142 |
Batch Mix Event |
143 |
| 3.11
Constant Pressure Events: IG |
144 |
| 3.12
Frictionless Adiabatic Process: IG |
145 |
| 3.13
About Enthalpy |
146 |
| 3.14
Constant Volume IG |
147 |
| 3.15
About Entropy |
148 |
Blowgun Hunter |
149 |
Skateboard Skill |
150 |
Newman's Annihilator |
151 |
Kids on a Swing |
152 |
SCUBA Horsepower |
153 |
What is cos(θ + 60°)? |
154 |
| 3.16 About Heat |
155 |
Hot, Heat, Cold... etc |
156 |
| 3.17 Heat and Work Sign Conventions |
157 |
| 3.18 Energy Equation I: SUBSTANCE |
158 |
| 3.19 Energy Equation II: SUBSTANCE |
159 |
| 3.20 Polytropic Processes: IG |
160 |
| 3.21 Events of Ideal Gases |
161 |
| 3.22 Rotational Kinetic Energy |
162 |
Air Pistol |
163 |
Air/Water Mortar |
164 |
Linear Elastic Work |
165 |
Tank, Spring and Heater |
166 |
Candle Beneath a Piston |
167 |
Average Force to Brake |
168 |
| 3.23 Mean Value Theorem |
169 |
Vacuum Launched Rocket |
170 |
Hot Shot |
171 |
| 3.24
Simple Springs |
172 |
Bungee Jumper |
173 |
Box moves between Two Springs |
174 |
Washer Switch |
175 |
| 3.25
Complex Substances |
176 |
| 3.26
Energy Rates and Power |
177 |
Elevator Speed |
178 |
Gravity Work-Rate |
179 |
| 3.27 Shaft Work |
180 |
Ship's Reduction Gear |
181 |
Horsepower of an Ox |
182 |
Truck Least Horsepower |
183 |
Tank Locomotion UNDER REVISION |
184 |
Cyclist Power UNDER REVISION |
185 |
Car Drives Uphill |
186 |
18-Wheeler Safe Braking Speed |
187 |
Atwood's Machine |
188 |
Deadweight Compactors |
189 |
Pulling Sheet Piles |
190 |
