Parachutist's Drag Force
Basic Thermodynamics ~ J. Pohl ©
www.physicsforums.com/thermo
Free FallSuppose a soldier (90 kilograms) parachutes from a C-130 Hercules moving at 350 ft/s. Further suppose an instance later, in free fall, the soldier experienced an acceleration of 6.8 m/s². Calculate the frictional drag force of the surrounding air at that instance of the fall?
Solution:  While standing in the C-130, the acceleration of the soldier is zero and his velocity is 350 m/s. An instance after the leap, his acceleration is Earthward at 9.81 m/s², the velocity part downward, part in the path of the C-130. downward is zero and so also is the resistance of surrounding air. Speed of fall through air increases, hence air resistance to that motion increases. Ultimately the speed of fall becomes "all the surrounding air" will permit... terminal velocity is attained.
Solution:  The term "force" is a signal that Newton's 2'nd Law applied to some "BODY" is the consideration. The physical property of the 2'nd Law is the momentum of the BODY.
A431 Eqn1
(1)(1)
Acceleration, (not a property but a spatial characteristic) of a BODY is relevant for systems having constant mass. The 2'nd Law for the parachutist (as a mass) in this case has two forces acting: that of gravity and fluid resistance or drag.
A431 Eqn2
(2)(2)
A system sketch should have been drawn with the person modeled as a BODY and the forces acting. Acceleration and forces are vectors; coordinates and a vector basis are required to state them. The sketch ( not done) would show the coordinates 0XZ with unit vectors I - J - K (with K upward or in the positive Z direction). The acceleration and gravity force are in the negative K direction. In the vector equation below, the drag force, its magnitude and direction, are the unknowns.
A431 Eqn3
(3)(3)
The above equation has only one unknown entity. So do algebra and calculator.
A431 Eqn4
(4)(4)
So, Newton's 2'nd Law, being a vector equation, states the force to have a magnitude of 270 Newtons and to be directed upward.
