Weight Shift at speed (acceleration and braking)
The discussion revolves around the dynamics of weight shift in various vehicles, including cars, hovercraft, and airplanes, particularly during acceleration and braking. Participants explore the implications of speed and forces on the center of gravity and weight distribution in these contexts.
  • One participant queries how to calculate the shift of the center of gravity (CG) when an object accelerates or decelerates, suggesting that understanding the relationship between weight, mass, and horizontal forces is key.
  • Another participant proposes that the change in normal forces on the axles during acceleration can be calculated using a specific formula involving the height of the center of mass and the vehicle's wheelbase.
  • A participant with a hovercraft emphasizes the need to determine the center of gravity at speed, noting that their air cushion suspension complicates the analysis compared to traditional vehicles.
  • One participant discusses weight transfer in motorcycles and other vehicles, explaining that weight and center of gravity remain constant until forces such as braking torque or aerodynamic effects come into play.
  • Another participant suggests that drawing a free body diagram is essential for understanding these dynamics, asserting that the center of gravity does not physically move during acceleration or deceleration.
  • A later reply acknowledges the complexity of visualizing the dynamics involved, particularly in three dimensions.
Participants express differing views on the movement of the center of gravity and the factors influencing weight distribution during acceleration and braking. No consensus is reached on a universal solution or approach to the problem.
Participants highlight the complexity of the dynamics involved, including the influence of different vehicle types and their respective mechanisms (e.g., air cushion vs. axles). There is also mention of the need for visual aids to better understand the concepts discussed.
kach22i
Let's say you have a body in motion, a car, an airplane or hovercraft - does not matter, looking for basic laws of physics here.
1. You know the weight.
2. You know the center of gravity at rest.
3. You know the center of lift (if applicable).
Let's say our object weighs in at 600 lbs.
Lets say our object is going 30 mph.
Q1:
How much does the center of gravity or weight shift back?
Q2:
Lets say I need to start or stop very quickly, how do I calculate the location shift of CG backwards and forwards?
I think the key is taking the the actual weight and turning it into mass, then take into account speed the horizontal force, which in turn may reduce the gravity force or weight over a given time peroid.
An actual example would help, then I can apply it to my situation.
I'm not sure I understand you. Say you have a car with known properties and start accelerating at a given rate. Are you looking for how the normal forces on the two axles change due to that acceleration? I suppose you could define an "effective" center-of-mass to be the position where the COM would have to be for the dynamic weight distribution to be the static one.
If this is what you're interested in, you can derive the result once the suspension motions have been damped out by calculating the forces and torques on the vehicle by the ground. The total torque should vanish, and the total force should be ma for a vehicle with mass m accelerating at rate a. If such a vehicle has center-of-mass height h from the ground and wheelbase L, the change in normal force on the front tires can then be shown to be
[tex] \Delta N_{f}/mg = - h (a/g) /L[/tex]
You can work out everything else pretty easily from that.
The car example is getting too complex, my suspension is an air cushion - this should be easier because there are no axles.
I have a hovercraft, but you may want to think of it as a boat on plane or planing if you are more familiar with that.
Even though I used calculations and a pipe to balance the craft, this balance is at static hover, not at speed.
I added too much weight in the back, but how do I determine the center of weight/gravity at speed?
http://www.hoverclubofamerica.org/forum/uploads/1165881286/gallery_181_6_20081.jpg
http://www.hoverclubofamerica.org/forum/uploads/1165881286/gallery_181_6_238757.jpg
Full thread of project:
http://www.hoverclubofamerica.org/forum/index.php?showtopic=962&st=0
Perhaps I've tried to find a universal solution that just does not apply.
Example of what I meant.
Weight Transfer-1
http://www.msgroup.org/TIP074.html
When you change speed (accelerate or decelerate) the weight of your motorcycle (including you) shifts in such a way as to put more or less load on your tires. You do not have to weigh the load on your tires to know this with certainty because you can see it happen by observing your front-end 'dive' when you brake.
Stern/rear hovercraft skirt drag might be a version of torque or braking power applied.
1. Car/Motorcyle; weight and center of gravity stay the same unless braking torque is applied or aerodynamic forces have an influenence.
2. Boat; weight and center of gravity are the same until displacement mode is replaced by planing mode, then there is a shift to the "center of lift". This is countered by tabs at the rear which induce drag counterforces and angle changes.
3. Airplane; weight and center of gravity are the same until speed increases lift on the wings causing a shift which is countered by the elevator (typically at the back).
4. Hovercraft; once it's over the "hump speed" which is also a boat term with a slightly diffenerent context, it is in level flight. Weight is centered until torque (paracitic skirt drag) is encountered in the form of wave impact and aerodynamic resistance.
No, the key is drawing a free body diagram.
The CG does not move anywhere. If you found Stingray's words too confusing, try a picture...
Thanks......it also take some imagination to visualize not just a line across a body in motion (right/left and front/back), but it's distance above a plane in 3D (up/down).
9K
14K
  • · Replies 65 ·
