What is the Theory Behind the One Electron Concept?
  • Context: Graduate
  • Thread starter Thread starter zforgetaboutit
    Electron Theory
The discussion revolves around the concept of the "one electron" theory, which posits that there may be only one electron in the universe that appears in different locations, creating the illusion of multiple electrons. Participants explore the implications of this idea, its origins, and its compatibility with established physics, including charge and quantum theory.
  • Some participants suggest that the identical measurements of electrons could imply there is only one electron that moves through space rapidly, appearing in multiple locations.
  • Others question the feasibility of this idea, particularly regarding how atoms can exhibit multiple negative charges if there is only one electron.
  • A participant introduces an analogy involving rocks in a dark room to illustrate how one electron could be perceived as multiple due to rapid movement.
  • Another participant references John Gribbin's work, suggesting that antiparticles might relate to the one electron concept, but expresses skepticism about its scientific validity.
  • Concerns are raised about the implications of charge and the effects of multiple electrons on atomic behavior, emphasizing that the effects of charge would still manifest regardless of the number of electrons perceived.
  • Some participants reflect on the philosophical implications of the idea, questioning why only electrons would be singular and not other particles like protons or neutrons.
  • There is a discussion about the nature of sameness and identity in quantum mechanics, with some arguing that the concept of identical particles may not hold under close scrutiny.
Participants express a range of views, with no consensus reached on the validity of the one electron theory. While some find the idea intriguing, others challenge its plausibility and implications, leading to a contested discussion.
Participants highlight limitations in understanding the nature of particles and their identities, suggesting that notions of sameness may not be straightforward in quantum mechanics. The discussion also touches on the implications of measurement and the uncertainty principle.
zforgetaboutit
My understanding is that electrons are one of the most highly measured entities in science. I'm not sure what the measurement is (mass/charge?) but it's known to maybe 10 significant digits.
Furthermore every electron seems to have the same metric, within experimental error.
Now, I read many years ago somebody suggested it's because there is only one electron in our reality.
It appears here, vanishes, reappears over there, again vanishes, with such rapidity it appears to be many electrons to our instruments. And the reason for the "identical" measurements is simply because its the SAME electron.
Does anybody know who first proposed this cute idea?
I don't know who suggested this idea, but I don't quite understand how it can be possbile. If there exists only one electron, how come an atom can have a [tex]2e^-[/tex] charge?
If you mean "double quantity negative" charge (sorry, I'm not familiar with your notation) then imagine this analogy:
You are placed in a dark room, against the middle of one wall. The room has a light capable of very fast switching. There is a rock opposite you in the right corner sitting on a scale. There is nothing special in the left corner. The light briefly flashes on/off. You see a rock, on a scale, and a measure wieght. The rock and scale is very quickly moved to the left corner where the light again flashes on/off. The rock/scale returns to the right corner. This process repeats indefinitely.
It seems you can see 2 rocks - one in each corner on a scale. They have identical characteristics it seems, even the same mass. Amazing! As far as you are concerned you accept they are separate rocks and, furthermore, exact twins, in the common sense.
Now substitute the word electron for rock and read it again.
I don't know who came out with the idea in the first place, but I'm almost certain I read something along those lines in John Gribbin's "In search of Schroedinger's Cat". The idea was that, since antiparticles can be regarded as particles going backwards in time, then you could see positrons (electrons antiparticles) as the only electron "going back" to make another trajectory for itself (in our perspective). It is indeed a nice image, but I don't think it has any scientific weight, since (even if compatible with observations) it seems to me thaht it has no predictive power. Besides, I think it should be possible to disprove it via weak decays or CP violation.
But I agree, it is a cute idea.
Sorry, it kind of fits but not completely. Because if you hold the scale in your hands, regardless of the state of the light, you will still only feel the weight of one rock. Whereas if you have an atom with "double quantity negative" charge, it will pull you twice as hard as an tom with only one negative charge - whether you "see" two electrons or not (and let's not forget the uncertainty principle), you will the effects of two.
If you carry 1 rock, quickly alternating between your hands, and conclude it's just as easy as 1 rock constantly in one hand, well I think both hands would eventually get too tired to carry anything - I.E. it eventually had the same effect as 2 rocks. 1 had the effect of 2. If you double the frequency and involve 2 people I think you could count the effect of 4 rocks.
I think the idea works if the frequency is high enough. The measuring device wouldn't have time to come to a resting position when wham! here comes another additive pulse, pushing it higher than a from-rest-single-pulse.
Ok, I can relate to that... but what makes the electron so special that there is only one of him in the whole universe? Why can't there also be one proton and one neutron? Besides if you go to a planet that manufactures cameras (for example) in an automated and precise process, wouldn't you expect that all cameras will be exactly the same? I think the fact that all electrons in the universe are precisely the same is just another aspect of the completeness and perfection of the Creation. :smile:
Well, we've measured electrons to a high degree of sameness; but we've never encountered your camera planet, so unfortunately I can't comment on it.
Show me the cameras first, and if they have an electron-matching degree of sameness, we'll carry on with the camera planet idea. :smile:
Just came across many joint attributions of this idea to John Wheeler & Richard Feynman.
Chen said:
... I think the fact that all electrons in the universe are precisely the same ...
Whoa! I didn't go that far. I'd say, all the observed ones so far are approximately the same.
As for the other particles, there might be only one each.
Just as a 'stickman' in a cartoon strip can not understand (prove) how 2D-drawn objects in his Universe can appear and then disappear, as the artist draws and then erases them, we may be unable to understand similar mechanisms happening in 5- or higher dimensional spaces as they appear to us in 4-space.
Or there may be an endless succession of Infinities, Cantor-style, without beginning or end whose cardinalities are supersets of preceding ones.
I'd say we have as much chance of understanding as a stickman is able to comprehend the existence (in our -space) of an artist, which is zero.
I'll always enjoy thinking about this stuff once in a while.
I wonder why John Wheeler did not advance a theory of one eye?
This is in accordance with quantum theory which posits every electron is identical to every other election, except for possible differences in their quantum states. So all electrons have precisely the same mass, same electric charge, same spin, and exactly the same weak and strong force properties...but they may have different locations, different spin directions and different energies for example.
ALL electrons are believed precisely identical in this sense...they are perfect twins...one is indistinguishable from another...all of which becomes more interesting regarding teleportation...
Naty1 said:
...ALL electrons are believed precisely identical in this sense...they are perfect twins...one is indistinguishable from another...all of which becomes more interesting regarding teleportation...
So you believe there are many electrons?
Notions like exact position, momentum, time, and energy break down when you look so closely at them. What makes you think that notions of same-ness remain.
When a particle drifts in space, is it really the same particle from instant to instant? Or does the first particle vaporize and another one appears? How can we tell in an experiment that two indistinguishable particles aren't switching places from time to time just because they feel like it?
Same-ness isn't as simple as you think it is. In math, is 1 the same as 1? Well yeah. But if the first 1 is a real number and the second 1 is actually 1 + 0i, a complex number, then maybe. A complex number has more structure than a real, but there is a very natural isomorphism between the two. In fact, it's so natural, we might even say they are exactly the same. Other similar isomorphisms exist, such as C and R^2. But we don't usually say that 1 + 3i is a vector in R^2. Yet, the situation isn't any different than between R and C.
So back to physics. What does it *mean* to say one particle is the same as the other? How are *you* defining same-ness here?
I don't BELIEVE anything,,,,I just rely on the standard theories, quantum mechanics in this case, and hope the interpretations of well known physicists have it mostly right... like Lee Smolin, Brian Greene, Roger Penrose, Stephen Hawking, Kip Thorne,etc ...I figure they'll be right more often I would ...but of course all of them have been wrong from time to time...
I too have heard of this concept, though I have no idea how much merit there is in it these days or how rigorous the idea is.
My understanding is that all electrons are identical in principle, not simply in experiment. i.e. if they were not identical, we would have to rework our understanding of physics.
Theory of one electron! ... so if a positron finds this electron and aniihilates it, it would destroy the whole universe! isn't it?
Identical electrons are an experimental fact, as identical atoms, etc. It should not be explained, it should be correctly implemented in the theory. Wheeler's idea is just absolutely wrong.
The 1 electron theory was proposed by Feynman. I have a 1965 paper he authored where he discusses this. He asked his professor if it is possible that every electron in the universe is merely the same electron. I'll find the paper and post it.
Richard Feynman is who I remember putting this theory forward.
Claude
Hm. That is a pretty compelling argument against the idea...
cabraham said:
The 1 electron theory was proposed by Feynman. ...
No, according to Feynman, it was Wheeler who called him and "explained" electron's being identical. Read Feynman's Nobel lecture.
this cannot be true, as if it were, when any atom lost an electron via the photoelectric effect, it would then have 0 electrons.
You are misunderstanding.
The hypothesis is not that "all electrons around an atom are the same electron", it is that "all electrons everywhere in the universe are the same electron".
The hypothesis is that one electron is moving forward through time, turning around moving backward through time, then turning around and moving forward through time, etc.
So, your atom with multiple electrons has an electron ejected from it. All other incarnations of that electron, including the other ones in the same atom, are unaffected.
No, the compelling argument against this hypothesis is: "What happens when a/the electron is annihilated with a positron?"
In this hypothesis, annihilation is the "turning around point", where an electron starts moving backwards in time and appears to us as a positron. Pair production is the same thing, although the hypothesis doesn't explain where that electron comes from - or why its the same as the earlier electron.
In any event, it's been known since 1964 that this model cannot be extended beyond QED. It predicts an exact symmetry under time reversal and we know that this symmetry is approximate in the real world.
D'oh! Of course.
Electron and positron moving forward in time and subsequently colliding.
- is equivalent to -
Electron moving forward in time, turning into a positron, which immediately begins moving backward in time.
that argument(that there is only 1 electron)is even more unlikely it seems, as we can make electrons collide, but how can something collide with itself? for something like that to happen, we would have to assume that there is some velocity at which you can travel such that you can actually outrun your physical body with your physical body, seems highly contradictory to me. for this to be the case, then we must now postulate a new theory, which is that if 2 electrons fired from independent sources "collide" what really happens is that the '1 universal electron' has established the same position in time due to 2 sources, thus meaning the resultant effect is nothing more than an interference pattern(similar to superposition), and not a result of an actual collision.
You are continuing to miss the point.
I do not see why you are missing the part where the electron travels backward in time, and then comes forward again, appearing to us as if it is a completely different and independent electron.
...you can actually outrun your physical body with your physical body, seems highly contradictory to me...
It is not contradictory if you allow traveling backward in time. Allowing that makes "colliding yourself with yourself" quite straightforward.
Please elaborate on how we know symmetry is approximate in the real world.
The Nobel prize winning experiment of Christenson, Cronin, Fitch and Turlay measured it.
I think I found the experiment. You were referring to C, CP, and CPT violation right? I haven't studied that yet. Perhaps next year when I take quantum. Thanks for the info.
  • · Replies 36 ·
10K
  • · Replies 26 ·
23K
  • · Replies 28 ·
