Differential equations - inverse laplace transforms
1 reply · 7K views
sugarplum31
We are given the following LaPlace Transformations and we are to find g(t) and h(t).
L(g)(t) = 1/[(1-e^(-2s))(s-1)]
L(h)(t) = (e^-s)/s(1-e^-s)
By looking at the Table of LaPlace Transformations, the only one I found that could possibly work for both of these is
f(t+T) = f(t) ---> (integral from 0 to T of e^(-st)f(t) dt)/ 1-e^(-sT)
For the first one, I broke it into two separate equations, 1/(1-e^-2s) * 1/(s-1) and for the second part it would be e^t. However, I am very confused on the equation I found in the Table and I'm not sure how to use it on either of these.
That formula makes it easy to compute the Laplace transform of a periodic function, but I don't see how it's going to make it easy to do the inverse transform. I think the following is a better approach.
* Use the summation formula for convergent geometric series:
[tex]\sum_{n=0}^\infty x^n = \frac{1}{1-x}[/tex], [tex]|x|<1[/tex].
Here, [itex]x=e^-Ts[/itex]. Since [itex]T>0[/itex], you can apply the above sum formula.
Once you have done that, then...
* Make repeated use the time shift property of Laplace transforms:
[tex]e^{-Ts}F(s) \longrightarrow f(t-T)U(t-T)[/tex]
I think you'll have more success taking that route.
