electricity generation without using magnet
by sleepsleep
Tags: electricity, generation, magnet
sleepsleep
sleepsleep is offline
#1
Jul6-08, 08:17 PM
P: 21
would like to ask, is that possible to generate electricity without using available electric and magnet?
is that if we don't have magnet, we wouldn't have electricity?
could the positive or negative field be gathered without using the magnet?
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
marcusl
marcusl is offline
#2
Jul6-08, 08:54 PM
Sci Advisor
PF Gold
P: 2,020
You can generate electricity by many methods without magnetic fields: chemical (batteries and fuel cells), solar (photovoltaic cells), and thermal (thermocouples, Seebeck effect). There are many biological generators as well (nerve and muscle tissues in your body) in addition to the obvious electric eels.
vishnukorde
vishnukorde is offline
#3
Jul10-08, 01:27 PM
P: 10
magnetism is based everywhere.. infact all natural forces together constitute matter, ie an atom is stable because of soo many factors..... factor also includes magnetism. hence if we say chemical energy is without magnetism...it is wrong.
ofcourse but we can produce electricity without magnets, ie by converting chemical energy into electricity.
DeepSeeded
DeepSeeded is offline
#4
Jul10-08, 02:16 PM
P: 113
You can generate electricty by rubbing your hands together... or more effienciently by rubbing cat furr on glass. Any sort of rubbing causes electrons to move and starts a chain reaction called electricty.
Crosson
Crosson is offline
#5
Jul10-08, 03:21 PM
P: 1,294
Quote Quote by sleepsleep View Post
Yes, it is possible to generate electric current by a chemical reaction, this is how disposable batteries work, for example.
I think you mean positive and negative charges, and yes they can be accumulated without magnets. This is also known as "static electricity", that sometimes shocks you when you touch metal after rubbing frictious materials together.
cshum00
cshum00 is offline
#6
May4-10, 10:15 AM
P: 213
Sorry for reviving this old thread but i thought that it would be better than creating a new redundant thread.
I have the same question but modified a little bit. Can large amount of electricity easily be created without using magnets?
Why do i ask that? Well, for we to have magnets we have to have electricity. Power plants use electromagnets which are powerful magnets generated by electricity. But for the electricity to be there for the electromagnets in the first place we have to have actual magnets to generate electricity. So, it feels like chasing after the chicken and the egg terminology here.
Therefore, i was wondering if something was done before that or if there is anything i am missing in the first place.
Bob S
Bob S is offline
#7
May4-10, 11:12 AM
P: 4,664
Linear Technology has just announced a new batteryless integrated circuit that "harvests" mechanical vibrational energy using a piezoelectric transducer to produce electrical energy for powering integrated circuits. See
http://www.linear.com/pc/productDeta...3,C1799,P90393
See datasheet at
http://cds.linear.com/docs/Datasheet/35881f.pdf
Bob S
cshum00
cshum00 is offline
#8
May4-10, 12:08 PM
P: 213
That's really cool but that is low voltage for ICs. My question was about large power energy generation.
Maybe to be more specific. I know power plants require electromagnets to generate electricity but for there to be electromagnets there have to be electricity first but for there to be electricity there have to be magnets. So, how i am in the magnet (chicken) and electricity (egg) infinite recursion problem.
russ_watters
russ_watters is offline
#9
May4-10, 03:28 PM
Mentor
P: 22,001
Quote Quote by cshum00 View Post
As said before, you can make as much as you want (and are willing to pay for!) with solar panels, thermocouples, piezo materials, etc.
I guess it is, but it has very little effect on the efficiency of generators.
gmax137
gmax137 is offline
#10
May4-10, 07:13 PM
P: 819
No, it isn't an infinite recursion problem, it ends in a battery ! In a commercial power plant, the batteries flash the field in the generator (energizing the field coils); then rotating the generator makes the electricity flow. No permanent magnets required. The original current from the batteries is chemical based (lead in acid). That's it.
vishnukorde
#11
May5-10, 10:03 AM
P: 10
nothing is done before that..! what happens is the core of the electromagnet retains a small part of the magnetic field whenever stopped. small amount of initial magnetic field is enough to get the generator started and in minutes completely magnetizes the core..! this magnetic field is used to produce electricity, small amount of energy does get discharged in producing the magnetic field but it is still convenient to have electromagnets instead of permanent magnets for it is too heavy and does not provide a provision to stop its magnetic interference when undesired.
mgb_phys
mgb_phys is offline
#12
May5-10, 10:17 AM
Sci Advisor
HW Helper
P: 8,961
Quote Quote by gmax137 View Post
No, it isn't an infinite recursion problem, it ends in a battery ! In a commercial power plant, the batteries flash the field in the generator (energizing the field coils); .
Starting a power station from scratch is tricky. It's called a black start and involves having lots of backup diesel generators to start the main turbines and generators spinning and to operate things like feed water pumps and air blowers.
Getting an initial field in the generator windings is generally the least of your problems.
It's more of a problem in micro-power systems (like small windturbines) a common solution is a DC generator with permanent magnets and a PWM circuit to synthesis AC.
cshum00
cshum00 is offline
#13
May5-10, 10:41 AM
P: 213
Thanks for the replies. Now this is getting better.
So, it means that starting from scratch is indeed a problem. First we have to create lead batteries and so on and the after having certain tools ready like permanent magnets and so on then we can actually start the plant generator easily. Is that what is happening?
Then to answer my own question, it means that that the source of energy that gives the start to generate electricity comes from actually an external source which has to be prepared before hand. Is that right?
mgb_phys
mgb_phys is offline
#14
May5-10, 11:02 AM
Sci Advisor
HW Helper
P: 8,961
You can make AC motors with permanent magnets if you wanted, but for large power stations it's more efficient to simply energize the main windings with a backup supply (either batteries or a DC generator)
In spite of DeepSeeded's excellent suggestion no major power stations keep a supply of cats on hand as an emergency black start electron source.
cshum00
cshum00 is offline
#15
May5-10, 12:15 PM
P: 213
Ok. But still, in my mind the problem is that to make permanent magnets one would still need some power source to actually store the energy into the magnets when you make permanent magnets for the first time. And so it is the same for the batteries. You need power source to power up the industry or machinery that makes batteries.
mgb_phys
mgb_phys is offline
#16
May5-10, 06:07 PM
Sci Advisor
HW Helper
P: 8,961
No, you can make a magnet by just hitting a piece of metal.
But not electricty, you can make a battery with two metals dug out of the ground and put in a beaker of acid
cshum00
cshum00 is offline
#17
May5-10, 06:27 PM
P: 213
Quote Quote by mgb_phys View Post
That is new to me. Is there anywhere can find more information about it? I thought that magnets where metal alloys where you have to charge them up with energy otherwise they would be just a regular metal.
Cool. Some manual labor but doable.
Bob S
Bob S is offline
#18
May8-10, 01:09 PM
P: 4,664
The external source is already available. I read somewhere that some types of big generators are aligned N-S to minimize voltages induced in the rotating armature by the Earth's magnetic field. So an unshielded rotating coil with its axis perpendicular to the Earth's magnetic field will generate a voltage.
Bob S.
Register to reply
Related Discussions
mechanical electricity generation General Physics 5
Electricity generation through crystals General Physics 10
electricity generation with magnets Electrical Engineering 0
The Physics Involved in Coal-Fired Generation of Electricity Introductory Physics Homework 1
Removing magnetism from a magnet with electricity? Electrical Engineering 1
