How to Disconnect a Car Battery at 11.8V Using an Adjustable Voltmeter?
  • Thread starter Thread starter trulka
10 replies · 3K views
trulka
Hey guys,
I am building an electric racecar for university and I'm stuck!. It has to be run on car batteries and it can only use one at a time... many people are just using an excellent battery with a great amp-hour rating... but I'd like to switch batteries halfway through...
I want to disconnect a car battery when it reaches 11.8V and possibly using an adjustable voltmeter/detector?
Please help, any advice would be great!
Thank you!
-Tom
You're not going to build much of a race car with only one 12V battery at a time. A single 12V battery, even at 100 amperes of current, is only providing 1,200 watts of power. This is about the same amount of power generated by a lawnmower engine.
- Warren
There are plenty of battery voltage detector chips about.
Maxim make a shedload.
Combined with suitably zonky Power mosfets, then bob's yer uncle.
You Brits sure talk funny :smile:
We've had centuries to practice... :biggrin:
Zonky, by the by, means "large" as in >100A Id(on).
One way for a warning system would be to setup a diode with a resistor (or trim pot) combination that switches at 11.8V.
What the heck does "then bob's your uncle" mean?
CS
It means you're problems are solved
Historical note:
Robert Gascoyne-Cecil,was prime minister in the 1890 and was a big fan of nepotism - appointing his nephew as minister, so if Robert (bob) was your uncle you didn't have any problems getting a job.
Interestingly neptosim is from the Italian for nephew and comes from Pope's giving appointments to their (cough) nephews (cough)
Historical note:
Ah...Thanks.
CS
Do I understand that both batteries will be in the car at all times, and you want a circuit that electrically switches over to battery #2 when battery #1 reaches 11.8V?
If this is for a contest, how will you convince the judges that only one battery is being used at a time?
