Nick89
- 553
Hi,
A while ago, we did a project at my university to construct a directional sound speaker; eg a speaker that does not emit sound in an omnidirectional way as usual but in a straight line (or at least as much as possible).
The goal was to research different approaches, choose the most appropriate one in our case and try to construct a working speaker.
We had found two approaches:
1. Using multiple sources and creating an interference pattern which causes the sound to destructively interfere at the sides of the speaker, and constructively interfere at the front.
2. Using ultrasound as some kind of 'carrier' for the audible sound; the theory being that ultrasound does not spread out in space so much as audible sound does.
The second option seemed to work much better, judging from devices that were on the market during our research, but also seemed way to complicated for us at that time. So we went with option 1.
We used 52 speakers (cheap piezo speakers) and arranged them in a hexagonal pattern, the crucial part being that each speaker was half a wavelength (6 cm) apart from its neighboring speaker.
This can be more easily understood if you imagine a line of speakers instead of a 2-dimensional pattern: the sound will then only be directed in the plane of the line.
If the speakers are half a wavelength apart, then speaker 1 and speaker 2 will cancel each other out at the sides, while speaker 2 and 3 will also cancel out, etc...
The following image portrays this effect for 2 speakers (warning: it's a fairly large image):
http://i36.tinypic.com/120o8it.png
The red circles represent troughs, while the black circles represent peaks. The resulting sound wave has been drawn right in front of the speakers (double height) and at the sides (canceling out exactly).
It can easily be seen that in front of the speakers, the troughs and peaks meet up with other troughs / peaks, and the result is again a wave alternating between troughs (red) and peaks (black), while at the sides, the peaks meet up with troughs and the troughs meet up with peaks thus canceling out.
Anyway, we managed to get it to work in the end. The effect is fairly obvious and there is a very sudden increase in sound level (about 30-40 decibels at most is what we measured) right about 20 degrees in front of the speaker (0 degrees being right in front of it, 90 degrees at the side). There is a very sharp 'edge' where the sound suddenly increases quite a lot; we have measured about 60 dB at the sides (90 degrees) and about 110 dB right in front.
However, while the difference in sound level is impressive for a 'simple 52-speaker' design, the 60 dB at the sides is still very much and the sound is still completely audible.Now finally on to my question (hehe). Last night on TV I was watching a show called Future weapons and a similar sound-directing 'weapon' was shown. Actually 2 were shown: one had properties similar to ours (except it went about 155 dB at the front so it was simply MUCH more powerful) and another was not so powerful but it had PERFECT directing abilities.
My question is about the latter: it was a square, very thin speaker, about 20 cm squared, and could direct audible sound perfectly. The guy aimed it away from the camera, turned it on and you heard nothing. Then he aimed it at a wall and the sound could be heard coming off the wall (it reflected). When he finally aimed it right at the camera the sound was crystal clear, like it had only just been turned on.
Now, at first I thought it was using the same principles as our design (interference pattern) but they said later it used ultra sound; sadly they did not elaborate how it worked...So: does anybody know anything about directing sound using ultrasound? How can it be explained that the device uses ultrasound, yet the sound is audible and at normal frequencies? Obviously the sound we hear is not the ultrasound but what is the purpose of the ultrasound then?
I have searched around (including the research we did in our project) and found a few products on the market (audio Spotlight and hypersound something off the top of my head) that claimed to work well, but nowhere could I find more than a very vague description of how exactly it worked.
I'm simply interested in this and I am wondering if it is something very hard to understand or not. I may find that it is beyond my knowledge of sound but please try me :p
So if anybody knows anything about this, any links where it is explained maybe, could you please point me there?
Thanks!
Thanks!
