Tire Pressure Gauge Reading at 44.2°C
  • Thread starter Thread starter PrideofPhilly
    Car Pressure Tire
8 replies · 8K views
PrideofPhilly
A car tire gauge is used to fill a tire to a gauge pressure of 42.5 lb/in2 on a cold morning when the temperature is -16 C. Atmospheric pressure is 14.7 lb/in2 and 0 C = 273 K.
What would the tire gauge read when the tire has been heated up to 44.2 C?
P2 = P1 (atmospheric pressure) + ϱgh (gauge pressure)
PV= nRT
P1/T1 = P2/T2
P2 = (14.7 lb/in2 + 42.5 lb/in2) = 57.2 lb/in2
I don't really know if this is even the right first step. I just recognized that gauge pressure is ϱgh. What should I do next?
Well, what is the ratio of the temps in Kelvin?
The ratio of T1/T2 = (257 K)/(317.2 K) = 0.8102143758
So what would you do with that? Multiply or divide into the 57.2?
I'm assuming multiply:
So, 57.2 psi X 0.8102143758 = 46.3 psi BUT THIS IS NOT THE RIGHT ANSWER!
Why would you assume the pressure would get smaller if the temperature increased?
If you divide:
57.2 psi/0.81 = 70.6 psi ALSO NOT THE RIGHT ANSWER!
The right answer is 55.8986 psi, so the pressure does get smaller.
PrideofPhilly said:
If you divide:
But 70.6 is not gauge pressure is it?
Oh...I got it. Thank you!
