Thread Closed
Tension Formula
Share Thread
Aug5-09, 09:55 PM   #1
Tension Formula
Hello... I'm brand new to Physics, going into 9th grade and got put into AP Physics BC so I got a large packet of Physics work and was told to learn the material and do all the work. I've been sort of stressed out since I barely understood half the questions, much less knew where to begin solving them. But hopefully this forum will be able to help me out.
This isn't really a question for a specific problem so I can really use the template. So my question is, is there a formula for tension? In other words, how would I find the tension on a string attached to a mass. I know that if the forces were equal then the tension = the weight, but what should I do if the mass is being pulled upwards/lowered downwards? I think the formula would be something like: Tension = Weight +/- Mass * Acelleration, but how would I write that scientifically?
Thanks in advance, and sorry for not using the template...
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Aug5-09, 10:43 PM   #2
First off, let me say wow if your in 9th grade taking AP physics C. Thats unheard of in my school. Secondly, there really is no equation for tension, as its just another force, and the cardinal equation for forces is [tex]\Sigma[/tex]F=ma (or in this case, F with a t subscript for tension). I suppose your equation Tension=weight +/-mass*acceleration is correct, but again, there is no formal equation for tension. The most important thing above all else, and this can never be stressed enough, is to draw a freebody diagram to see how each force is acting on each body.
Now suppose you had a system where a rope is pulling up a block of mass m with force Ft, and acceleration (a). Heres how i would write out my work if this were a test:
1)[tex]\Sigma[/tex]F=ma
2)Then specify each force: Ft-Fg=ma
3)move around: Ft=ma+Fg (or you can make in mg at this point)
4)Simplify:Ft=m(a+g)
Now of course, this problem gets more annoying if it involves an atwood machine, or a machine that has two masses connected by a rope over a pulley. the problem becomes an even bigger pain when the pulley is given a moment of inertia, but you can save that for later
Aug5-09, 10:47 PM   #3
Recognitions:
Homework Helper Homework Help
In almost all cases where you're asked to find the tension, you have to use Newton's second law. In the case of a mass hanging on a string, that would be mg-T=ma, a=0, so T=mg.
Other than that, there can be no formula for tension any more than there can be a formula for speed. The tension on a rope is simply the force exerted on it, and that depends on what's exerting the force.
Aug5-09, 10:48 PM   #4
Recognitions:
Tension Formula
Oops, edit conflict. I bow to LBloom's superior answer. :)
Aug5-09, 10:54 PM   #5
Oh, I understand now. I somehow overlooked gravity. The rest of the explanation makes sense too... no wonder nothing came up when I searched for the "tension formula". Thanks!
Thread Closed
Tags
formula, tension
Similar discussions for: Tension Formula
Thread Forum Replies
Formula help needed... algebraic formula for intra-interval rate of acceleration General Math 2
Differences between the Francis Formula & Torrecelli Formula Classical Physics 0
Consequences of Cauchy's Formula (differential formula) Calculus & Beyond Homework 1
Difference between applied tension and tension due to weight? Introductory Physics Homework 2
String tension, is this the correct formula? Beyond the Standard Model 2
