Well, if the boat has displaced so much water, and it is not sinking or being pushed up out of the water, then the density of the water, times the volume of water displaced gives you the mass of the water displaced. Multiply this by the gravitational constant and you get the weight of the water displaced. This is equal to the weight of the barge. In general, the buoyant force on an object is equal to the weight of the liquid displaced, and if an object is floating, the buoyant force and gravitational force (which is the exact same thing as the weight) are equal, but in opposite directions.
To solve your problem of whether an aluminum barge can carry more than a steel barge or a concrete barge, I'd have to know the basic shape of these barges, their dimensions, and their densities or weights/masses. Assuming that all the barges are the same shape and dimensions, then the barge made of the least dense material will fare best, that is, the barge with the least density, or equivalently, the least weight, or equivalently the least mass.
