Show Roots of Complex Sine Are Real Valued
13 replies · 11K views · last reply
mancini0
Hi guys, I am having difficulty with the following problem:
Show the complex sine function has real valued zeros.
I know that sin(z) = (e^iz - e^-iz) /2i
I have to find roots of sin(z), i.e, when the above equation = 0. First I multiplied both sides by 2i, to cancel the 2i in the denominator.
leaving e^iz -e^-iz = 0.
then e^iz = e^-iz .
So e^iz = 1/e^1z
Now I am stuck. I can break it down to trigonometric form, but I'm not sure how that helps...
cos(z) + i sin(z) = 1 / cos(z) + i sin(z)
I think I have to get the above expression into real and imaginary (u and v) parts:
cos(x+iy) +i (sin(x+iy) = 1/[cos(x+iy) + i*sin(x+iy)]
Any guidance would be much appreciated...
Thanks!
Factor it. 0=e^(iz)-e^(-iz)=e^(-iz)*(e^(2iz)-1). The first factor is never zero, right?
Hmmm... so the roots are when e^(2iz) - 1 = 0, i.e, when e^(2iz) = 1.
e^(2iz) = e^(iz) * e^(iz) = (cos(z) + isin(z) ) * (cos(z) + isin(z))
1= cos^2(z) - sin^2(z) + i(sin(z)cos(z))
Recognizing that cos^2(z) - sin^2(z) = cos(2z), I can rewrite the above as
1 = cos(2z) + isin(z)cos(z)
Now my intuition tells the above must be real valued, since I feel that whatever I put in for z which satisfies the above equation will cancel the imaginary part. I just don't know how to solve the above equation in the complex plane, i.e, how would I expand cos(z) to cos(x+iy)?
Work out what e^(2iz) is when z=x+iy. Then set that to 1.
micromass said:
Isn't there an easier way to solve e2iz=1 by simply taking logarithms?
If you happen to know log is multivalued and all that stuff. I think a more basic approach might be better here.
e^2(iz) = e^2i(x+iy) = e^(2ix -2y)
= e^2ix / e^2y since subtraction in the exponents corresponds to division of base.
The above = 1 when e^2ix = e^2y
i.e, when 2ix = 2y, when ix = y
x = -iy
We haven't discussed the complex logarithm, that comes tomorrow! I don't see how my above solution shows sin(z) is always real valued.
x = -iy
No, no. The complex function e^z isn't one-to-one. You can't cancel it like that. Use deMoivre on e^(2ix). You know a lot about the REAL sine and cosine functions.
Hmmm, I think it hit me...if x = -iy, then z=x+iy implies z = -iy +iy = 0 is the root.
See my previous post.
Okay, thank you very much for your help thus far.
By De Moivre's Theorem I would take the nth power of the modulus and multiply the argument by n.
But why would I do this on e^2ix? I thought De Moivre's theorem only applies when a complex number is raised to an integer?
[tex]\sin(z)=\sin(x)\cosh(y)+i\cos(x)\sinh(y)\,,\ \text{ where }\ z = x + iy[/tex]
So sin(x)cosh(y) = 0 and cos(x)sinh(y) = 0 .
e^(2ix)=cos(2x)+i*sin(2x). That's all I meant. So 1=(cos(2x)+i*sin(2x))*e^(-2y). First notice that the imaginary part has to vanish. What does that tell you about x? Use that to deduce what y must be.
