Equation of Tangent Plane with Vector-Valued Function
3 replies · 4K views · last reply
atm1993
Find an equation of the tangent plane to the vector valued function at the origin, (0,0,0).
I don't really know how to start. I've been reading and searching around for quite a bit. I know how to do the problem with a regular function, using the partial derivatives of a function and such, but I'm not really sure where to go with this vector-valued function.
atm1993 said:
Find an equation of the tangent plane to r(u,v) = uvi + ue^vj + ve^uk at the origin, (0,0,0).
The first step is to figure out what u and v give R(u,v) = <0,0,0>.
Then use the fact that Ru X Rv evaluated at that point (u,v) gives a normal vector to the plane. You can use that to write its equation.
Alright, so I worked it out and I want to see if I'm on the right track following what you said.
For the function to = <0,0,0>, (u,v) would have to be (0,0). I then found the partials of the function with respect to u and v.
ru(u,v) = vi + e^vj + ve^uk
and
rv(u,v) = ui + ue^vj + e^uk
I then evaluated both of those at (0,0), resulting in
<0, 1, 0> and <0, 0, 1>.
Crossing those resulted in <1, 0, 0>, which then leaves me with an equation of a plane as x=0, using the point (0, 0, 0).
I'm not completely sure if I did that correctly.
and
That looks correct to me. It just says your surface is tangent to the yz (x=0) plane at the origin.
