Capacitance of capacitor with unevenly charged plates
The discussion revolves around the capacitance of a parallel plate capacitor with unevenly charged plates, specifically where one plate has a charge of +aQ and the other -bQ. The original poster expresses confusion regarding the appropriate value of 'Q' to use in the capacitance formula, given the differing charges on the plates.
  • Participants explore whether a parallel plate capacitor can have different charges on each plate and question the implications of this scenario. There is discussion about the necessity of equal charges on both plates and the conditions under which charges might differ.
The conversation is ongoing, with participants presenting various viewpoints and questioning assumptions about charge distribution in capacitors. Some guidance has been offered regarding the behavior of charges on conducting plates, but no consensus has been reached on the original poster's question.
There are references to electrostatic principles and the behavior of charges in capacitors, but the discussion remains open-ended with no definitive resolution to the original question about capacitance with uneven charges.
PedroB
I'm almost embarrassed to post this, but insofar none of my searches online have yielded any results. My question is simply, given a parallel plate capacitor (for the purpose of simplicity let's assume that there are no edge effects) whose constituent plates have charge +aQ and -bQ (a and b are some random number) respectively, what is the capacitance?
C=Q/V
My main problem lies in determining what the 'Q' term in the equation above is. Is it simply an average of both charges? (Both plates have the same area in this example) All examples I have seen so far assume both plates have the same charge, and I've not been able to find an example where this is not the case. Thank-you in advance.
different charges?
can a PPC have different charges on each plate. I don't think so. a must equal b. if one plate is +aQ then the other has to be -aQ. therefore your capacitance should be C=aQ/V
Are we sure about this? "can a PPC have different charges on each plate. I don't think so"
Lets assume I have a capacitor and charged it with a battery. Then I touched one lead of the cap to ground. Would the charges on the plates still be equal? Just asking.
don't you have to connect both leads to discharge a capacitor?
I am not sure. I recall a electrostatic problem where there are two spheres with different charges. Isn't this like a capacitor with different charges on the plates? I am just asking. I don't know the answer.
Hello PedroB
When charged conducting plates are placed parallel to each other ,the two outermost surfaces get equal charges and the facing surfaces get equal and opposite charges i.e let plate A has charge Q1 and plate B has charge Q2 then the charge on outermost surfaces of both the plates will be (Q1+Q2)/2 .The innermost surfaces will have charge (Q1-Q2)/2 and -(Q1-Q2)/2 .
To get this result use Gauss Law and the fact that the electric field inside a conductor in electrostatic condition is zero.
Hope this helps .
Tanya Sharma said:
Hello PedroB
Hope this helps .
i agree with this.
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 18 ·
