How Do You Construct a [4, 7^2, 3] Code Using MOLS?
  • Context: Graduate
  • Thread starter Thread starter SomeRandomGuy
    Coding Homework Theory
The discussion revolves around the construction of a [4, 7^2, 3] code using mutually orthogonal Latin squares (MOLS). Participants explore the implications of the notation, the requirements for constructing the code, and the relationship between MOLS and the code's parameters.
  • Homework-related
  • One participant asserts that a [4, 7^2, 3] code exists due to the prime nature of 7, suggesting there are 6 MOLS available for construction.
  • Another participant questions the feasibility of encoding 49 symbols in a codeword of only 4 symbols, expressing uncertainty about the acronym MOLS.
  • A participant clarifies that MOLS stands for mutually orthogonal Latin squares and speculates that the notation refers to a 3-error correcting code with 7^2 codewords of length 4.
  • There is a suggestion that the construction might yield codewords of length 8, and a question is raised about whether the original poster is struggling with producing MOLS or constructing the code from them.
  • One participant confirms the understanding of the notation and explains that the minimum distance refers to the separation between codewords, which simplifies the construction process by requiring only 2 MOLS instead of 6.
Participants express differing levels of understanding regarding the construction of the code and the implications of the notation. There is no consensus on the best approach to constructing the code, and some uncertainty remains about the requirements and definitions involved.
There are unresolved assumptions regarding the definitions of MOLS and the parameters of the code, as well as the implications of the minimum distance on the construction process.
SomeRandomGuy
Construct a [4, 7^2, 3] code. I know it exists because 7 is prime, so there are 6 MOLS. However, I am not quite sure how to go about constructing this code.
You sure you have that right? You can't encode 49 symbols in a codeword that's only 4 symbols long.
I don't know the acronym `MOL' either.
This sounds like a homework question -- you can usually metareason these out: it would probably be done using a code (or a technique) that you learned recently.
MOLS=mutually orthogonal latin squares
I'm not positive what the (4,7^2,3) notation refers to, I'm guessing a 3-error correcting code with 7^2 codewords of length 4 (7 symbols each position?).
The construction I have in mind would make codewords of length 8 though. This is a pretty standard construction, and assuming it's what you're trying to do: are you having problems producing the MOLS or coming up with the code given a set of 6 MOLS? (or both?)
Yes, MOLS is mutually orthogonal latin squares. the notation (4, 7^2, 3) referes to an [n, M, d] code where n is the length of each vector in the code, M is the number of vectors, and d is the minimum distance between them.
Anyway, I figured it our, so it's all good. Thanks for the responses.
ahh, 3 being minimum distance and not the level of error correction would explain how length 4 code words will be sufficient. Much simpler to construct the code when you only need 2 MOLS and not 6!
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 0 ·
