Proving Piecewise Continuity of f(x)=x^2(sin[1/x]) in (0,1)
  • Thread starter Thread starter barksdalemc
    Continuity
The discussion revolves around proving that the function f(x) = x^2(sin[1/x]) is piecewise continuous on the interval (0,1). Participants are exploring the nature of continuity and discontinuities of the function within this context.
  • Participants are questioning the interpretation of the function and its continuity, with some suggesting that the function is continuous on (0,1) and thus piecewise continuous. Others are considering how to partition the interval and whether discontinuities exist at the endpoints.
The discussion is ongoing, with participants offering differing views on the continuity of the function and the implications of the definition of piecewise continuity. Some have provided insights into the limits involved, while others express confusion about the nature of discontinuities.
There is a focus on the definition of piecewise continuity and the conditions under which a function can be considered piecewise continuous, including the potential for zero discontinuities. Participants are also grappling with the implications of limits as they approach the endpoints of the interval.
barksdalemc
I have a question that asks to show that f(x)=x^2(sin[1/x]) is piecewise continuous in the interval (0,1). I need to show that I partition the interval into finite intervals and the function is continuous within the subintervals and have discontinuities of te first type at the endpoints. I tried using any multiple of pi. That doesn't work. Any hints?
Is that:
[tex]x^2 \sin \left \frac{1}{x} \right[/tex]
? Because that function is just continuous in (0,1), so it's obviously piecewise continuous. Or does [1/x] mean the integer part of 1/x? If so, then it seems like the natural thing to do is divide up (0,1) into the regions where [1/x] takes distinct values (ie, (1/2,1],(1/3,1/2], etc.).
Is the correct function, which you indicated. The exact question is as follows:
A function f is called piecewise continuous (sectionally continuous) on an interval (a,b) if there are finitely many point a = x(sub o) < x(sub 1) < ... < x(sub n) = b such that
(a) f is continuous on each subinterval x(sub o) < x < x(sub 1) , x(sub 1) < x < x(sub 2) , ... , x(sub n-1) < x < x(sub n), and
(b) f has discontinuities of the first kind at the point x(sub o),x(sub 1), ... , x (sub n). The function f(x) need not be defined at the points x(sub o),x(sub 1), ... , x (sub n). Show that the following functions are piecewise continuous:
f(x) = [tex]x^2 \sin \left \frac{1}{x} \right[/tex] , 0 < x < 1
Right, and do you see why that is continuous in the ordinary sense (or piecewise continuous with a trivial partition of (0,1))?
It seems like the question wants a further partition of (0,1). The left limit doesn't exist here so I'm confused as to why the function has a discontinutiy of type 1 on the trivial interval (0,1)
Well the left limit does exist, but this doesn't matter because 0 isn't in your range. The fact is there are no discontinuities anywhere. A function doesn't have to have any discontinuities to be piecewise continuous. The definition you gave above is a little awkward, but it doesn't rule out the possibility that the number of discontinuities is zero (which is finite), and this is certainly allowed.
Maybe I don't understand the definition of the limit then. As we approach 0 the lim sup from the right is not the same as the lim inf from the right, therefore the limit from the right does not exist.
What do you get as the limsup and liminf?
0 for both. My bad.
  • · Replies 40 ·
  • · Replies 20 ·
