Integralx^3sqrt(4-9x^2)dx with limits of integration at 2/3, 0 (trig subst)
The discussion revolves around evaluating the integral of the function x^3√(4-9x^2) with limits of integration from 0 to 2/3, utilizing trigonometric substitution. Participants explore the implications of the substitution and the transformations involved in the integration process.
  • Mixed
  • Participants discuss the trigonometric substitution x = (2/3)sin(θ) and the corresponding differential dx. There are questions about the accuracy of the transformations and whether coefficients were properly accounted for during the substitution process. Some participants suggest re-evaluating specific steps to identify mistakes.
The conversation is ongoing, with various participants providing insights and corrections regarding the substitution steps. Some guidance has been offered on how to properly handle the coefficients and the transformation from dx to dθ. There is no explicit consensus on the final answer, as participants continue to explore different aspects of the problem.
Participants note the complexity of the integral and the potential for errors in the substitution process. There are references to the need for careful attention to detail in the transformations and the handling of coefficients, indicating that the problem may be challenging due to these factors.
evilpostingmong
x=sqrt(4/9)sin theta
dx=sqrt(4/9)cosine theta
sqrt(4-9x^2)
sqrt(4-9*4/9sin^2theta)
sqrt(4-4sin^2theta)
sqrt(4(1-sin^2theta)
sqrt(4cos^2theta)
2costheta
Integralx^3*2cos theta dtheta
Integral sin^3*2cos theta dtheta
Integral (cos^2theta-1)*sin theta*2cos theta dtheta
Integral (2cos^3 theta*sin theta dtheta)-Integral (2cos theta sin theta dtheta)
u=cos theta
du=sin theta dtheta
2u^4/4du-2u^2/2du
(2cos^4 theta/4)-(2cos^2 theta/2)
since x=sqrt(4/9)sin theta
x=opposite
sqrt(4/9)=hypoteneuse
and sqrt(4-9x^2)=adjacent
so 1/2sqrt(4-9x^2)^4-2/2sqrt(4-9x^2)^2+C
then plug in the numbers.
The number that I got was different from the books. Help is appreciated
since this problem is driving me crazy. Thank you!
Remember to keep your coefficients well marked up. =P
I haven't finished the problem yet, but I can already tell you did that wrong. Go back and do them long hand:
u = a*sin(theta)
du = a*cos(theta) d(theta)EDIT:
The answer I got was .1333333 repeating. Was that right? If it is, then check over your beginning again for coefficient mistakes.
Okay, let's go to the step where you've just carried out the trig substitution for x in one of the factors, but not the other. You have
[tex]\int_0^{\frac{2}{3}} 2x^3 \cos \theta \, dx[/tex]
My question is, how come you wrote [itex]d\theta[/itex] instead of [itex]dx[/itex], without first converting the [itex]dx[/itex] into [itex]d\theta[/itex] properly?
Also, how come when you made the trig substitution for [itex]x^3[/itex], you got
[tex]\sin^3 \theta[/tex]
instead of
[tex]\left( \frac{4}{9} \right)^{\frac{3}{2}} \sin^3 \theta[/tex]
instead of
?[/QUOTE
Oops, sorry, that was a stupid mistake on my part (leaving out sqrt(4/3))
Never mind him, was my answer right?(.133333333)
The answer is 64/1215.
Omg, no LaTeX. My eyes are hurting. :cry: :cry: :cry:
You should try to learn LaTeX, it's extremely convenient.
You mean this: [tex]\int_0 ^ \frac{2}{3} \ x ^ 3 \sqrt{4 - 9 x ^ 2} \ dx[/tex]. Right?
Well, sqrt(4/9) is actually 2/3. You can rewritten the whole thing as:
x = (2/3) sin theta
dx = (2/3) cos theta d(theta)
sqrt(4-9x^2)
sqrt(4-4sin^2theta)
sqrt(4cos^2theta)
2costheta
So far, so good. :)
This is where you went wrong.
When chaging dx to d(theta), and x to sin theta, and cos theta you forget the factors.
x = (2/3) sin theta
You accidentally dropped out the 2/3 factor.
u=cos theta
du=sin theta dtheta
2u^4/4du-2u^2/2du
x=opposite
Well, you should re-do this part. :)
There's one more convenient way to tackle this problem, i.e to use u-substitution. x3, can be splitted into x2 x
Letting u = x2
The whole thing become:
[tex]\int \ x ^ 3 \sqrt{4 - 9 x ^ 2} \ dx = \frac{1}{2} \int \ u \sqrt{4 - 9u} \ du[/tex]
Another u-substitution will do it. Can you go from here? :)
Wow, thanks VietDao, but I'm going to see if I could get it done the traditional way to see where I went wrong barring the stupid mistake...
Integral (2/3)sin^3*2cos theta dtheta
Integral 2/3(cos^2theta-1)*sin theta*2cos theta dtheta
Integral 4/3cos^3theta*sin theta d theta-Integral 4/3 cos theta sin theta d theta
u=cos theta
du=sin theta d theta
4u^4/12-4u^2/6
4cos^4 theta/12-4cos^2 theta/6+C
Whoops, it's still wrong =.=" You've messed up the coefficients.
Ok, let's do it step by step then.
Since x = (2/3) sin(theta)
x3 = (2/3)3 sin3(theta)
dx = (2/3) cos(theta) d(theta)
Change all x to theta, we have:
[tex]\int \left( \frac{2}{3} \sin ( \theta ) \right) ^ 3 \sqrt{4 - 9 \times \frac{4}{9} \sin ^ 2 \theta} \left( \frac{2}{3} \cos \theta \ d ( \theta ) \right) = \int \frac{8}{27} \sin ^ 3 ( \theta ) \left( 2 \cos \theta \right) \left( \frac{2}{3} \cos \theta \ d ( \theta ) \right)[/tex]
Now, hopefully, you can take it from here, right? :)
Integral 32/81 (1-cos^2theta)*cos theta*sin theta d theta
Integral 32/81 cos theta *sin theta d theta-Integral 32/81 cos^3 theta * sin theta d theta
u=cos theta
du=sin theta
32u^2/162-32u^4/324
32cos^2 theta/162-32cos^4 theta/324
Well, the first line is incorrect. >"<
Actually, it is cos2(theta) instead of cos(theta). Common, try again one more time, man, you are very very close to the answer. Just correct some minor mistakes, and it's done. :)
u=cos theta
du=sin theta
Oh, and by the way. If u = cos(theta), then du would be: du = -sin(theta)d(theta)
Then I'll just simply change the first line to
Integral 32/81 cos^2 theta sin theta d theta- Integral 32/81 cos^4 theta sin theta d theta
u=cos theta
du= -sin theta d theta
32u^3/243-32u^5/405
32 cos^3 theta/243-32 cos^5 theta/405:wink:
u=cos theta
32u^3/243-32u^5/405
Well, you still got the wrong signs, though. du = -sin(theta)d(theta). There's a minus sign in front of it. :)
Ok, well, yeah, just change the signs, and you'll arrive at the final answer. :) ^.^
32cos^3 theta/243+32cos^5 theta/405
No... It's still wrong. :cry: :cry: :cry: :cry:
-(a - b) = -a + b, not a + b
You should flip both signs.
-32 cos^3 theta/243+32 cos^5 theta/405
Well, you should do some more manipulations, it's good for some problem like this, i.e, require a lot of calculation.
Btw, congratulations. Finally, you got it :)
  • · Replies 22 ·
10K
