Tension in Strings HELP thanks-very simple.
  • Thread starter Thread starter physicsbhelp
    Strings Tension
The problem involves a 16 kg object in equilibrium suspended by a string with a specified length and linear mass density, interacting with two pulleys. The discussion focuses on determining the tension in the string and the frequency required for a standing wave pattern.
  • Mixed
  • Participants explore the equilibrium condition of the forces acting on the hanging mass, questioning how to relate tension to gravitational force. Some attempt to calculate angles and components of forces using trigonometry, while others express confusion about the setup and calculations.
The discussion is ongoing, with participants providing hints and guidance on analyzing forces and components. There is a recognition of the need to clarify the angles involved and how they relate to the tension in the string.
Participants are grappling with the implications of equilibrium and the geometry of the problem, including the angles formed by the strings and the vertical components of the forces. There is mention of significant figures and the importance of accurate calculations in the context of the problem.
physicsbhelp
[SOLVED] Tension in Strings HELP thanks!--very simple.
A 16 kg object hangs in equilibrium from a string with a total length of L=5m and a linear mass density of u= 0.0010 kg/m. The string is wrapped around two light, frictionless pulleys that are separated by a distance of d=2.0m.
A) Determine the tension in the string.
B) At what frequency must the string between the pulleys vibrate in order to form the standing-wave pattern shown in Figure b)?
Picture is attached!
If there was an axis at the bottom of the inverted triangle and the angles were measured from the axis to the strings;
I have also tried using;
v = Square root of (tension/u), but I don't have v,
So i tried to find v using f = v/ wavelength, but i don't have frequency.
I have tried so many things and I can't seem to get a start. Any hints?
Since the 12kg mass is stationary, what can you say about the sum of the forces acting on it?
since its in equilibrium the net force must be 0.
acknowledge all the forces in the y direction.
tension upwards
gravities pull downward..
since their total combined force is 0 due to mr.Newton
then tension must be equal to gravities pull, besides direction
(assuming the weight is connected to one string)
tension upwards
Wow physicsbhelp! You said that without even moving your lips...:rolleyes:
wait so is the tension equal to gravity? i typed in 9.81 and it said it was wrong so i typed in -9.81 and it said that was wrong too! i am still in need of help!
9.81 m/s^2 is the acceleration due to gravity (for an object in freefall). What's the weight of the 16 kg mass?
ooo the weight would be 16*9.81? = 156.96. i typed that in and it was also wrong.
so what else could it be?
If I understand the setup correctly, then that would be the tension in the string (in N). How fussy is the system about significant figures? Round it off. (You certainly don't have 5 significant figure accuracy!)
no that is not the answer. i didnt even round up on the real answer.
okay i attached the diagram. i think that will help. part a) has to do with picture a).
Providing a diagram makes a huge difference! Now it's clear. :wink:
Analyze the forces acting on the hanging mass. You know it must be in equilibrium--that will allow you to figure out the tension. (First figure out the angle the strings make.)
what angle are you talking about? like the angle that the string makes with the object? i thought it was a 45 45 90 triangle. but i still don't see how angles will help find tension. is there an equation for that.
How did you figure out those angles? Don't guess--they gave you the length of the string for a reason. Once you have the angles, then you can draw yourself a free-body diagram of the forces acting on the mass. (The tension acts along the strings--that's why you need the angles.) The equation you need is the equilibrium condition, specifically: The sum of the vertical force components must equal zero.
i am still not quite understanding this equilibrium angle equation.
so the base of the inverted trianlge is 2 meters and the two sides are 1.5 meters long each. then i still don't get the angles. or basically how to find them.
Draw your own diagram, marking the lengths. Then use a little trig to find any angle you might need. Hint: Draw a vertical line passing through the mass. Use that as a reference.
i drew my triangle the way u said. but i still don't seem to get it. like the vertical line passing through the mass is 1.118 meters. i figured that out. but i can't tell how to do trig? like do i do cos (1/1.5)?
OK.
What's the cosine of the angle that the string tension makes with the vertical? You'll need that when you write your force equation. (Write that equation!)
ooo wait i think i just got it! the whole time my calculator was in radian mode, that is why i kept getting weird answers. haha.
okay so for the ablge between the side that equals 1meter and 1.5 meter i got 48.187 degrees and for the other angle i got 41.81 degrees.
now i really don't know how i can find out the tension.
Call the unknown tension in each string T. Draw a diagram showing the forces. Add up the vertical components. Solve for T.
i did that but i have no numerical values. i got that 2Ft=Fg? is that right?
or is it not?
That would be true if the strings were vertical, but they are not. If the tension in each string is T, and the angle that the string makes with the vertical is [itex]\theta[/itex], what is the vertical component of the force that each string exerts on the mass?
Ft(theda)
or
Read this: http://www.glenbrook.k12.il.us/GBSSCI/PHYS/Class/vectors/u3l3c.html"
well that sort of helped. but I am asking for the tension in the string, not for the Net Force of the string on the OBject
Can you find the net force of the string on the object? What's the only other force on the object? Add them up to get zero and you can solve for the tension.
Look at the problems described on that page. Almost the exact problem that you have is discussed several times.
so gravity plus the tension of the string on the object equals 0
Yes, the net force on the mass is zero. As I've stated several times over.
Find the vertical components. Learn how to do that or you're just wasting time. Read the examples on that website.
but i don't know how to do that. i read the website you sent
i don't get it. like i konw what vecotrs are ut can you say they are distnace?
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 23 ·
