What is the frequency of the tuning fork?
The problem involves a tuning fork vibrating above a vertical open tube filled with water, with the objective of determining the frequency of the tuning fork based on the resonant lengths of air above the water level. The context includes the speed of sound in air and the relationship between the lengths and the harmonics of a closed tube.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the formula for the frequency of a tuning fork in a closed tube and question the correctness of the provided lengths for resonance. Some participants attempt to derive the wavelength based on the difference between the two lengths, while others express uncertainty about the necessity of using both lengths.
There is a mix of attempts to clarify the relationship between the lengths and the wavelength, with some participants providing calculations that lead to different frequency values. The discussion reflects a lack of consensus on the interpretation of the problem, but there is engagement with the mathematical relationships involved.
Participants note potential issues with the given lengths and the assumptions regarding the harmonic relationships in a closed tube. There is an acknowledgment of the complexity of the problem as it relates to the physics of sound and resonance.
K3nt70
A tuning fork is set into vibration above a vertical open tube filled with water, as seen in the figure below.
http://img207.imageshack.us/img207/5817/dgian1686mm6.gif
The water level is allowed to drop slowly. As it does so, the air in the tube above the water level is heard to resonate with the tuning fork when the distance from the tube opening to the water level is L1 = 0.100 m and L2 = 0.450 m. What is the frequency of the tuning fork? Assume that the speed of sound in air is 343 m/s.
f1 = [tex]\frac{\upsilon}{4L}[/tex]
where v = 343 m/s
I know that when the distance between the tuning fork and surface of the water is 0.1m. This means it is the first harmonic. Since it it a closed tube, i use the formula for the first harmonic of a closed tube, but my frequency comes out to 858 Hz which is incorrect.
I'm sure that i have to use the second length they give to us, but I'm not sure what its for..
cheers
Errr, I think the question is wrong or something, because the resonant lengths are supposed to be 1/4 lambda (lambda is wavelength), 3/4 lambda, 5/4 lambda, etc...
So I think either your L1 or L2 is incorrectly given. But otherwise, I think the formula you're using should be fine...I don't think you have to use L2. Maybe they put it into trick you? Haha, hope that helped a little?
well. I'm fairly sure the question is correct; when there are problems with assignment questions, they can change them asap (since its over the internet). And seeing as this assignment is somewhat old, (im reviewing for a test) they've had a lot of time to fix it ;P
Oh, I just did this
Well, v=fLambda
Lamda=2(L2-L1)
so Lambda=.7
so now 343=fLambda
f=343*.7
f=247.1
Hope that helps
oh. yeah. warmfire540's answer looks right. gee...this is a good sign... i have a physics exam on monday and i can't get these questions right!
Its actually f = v/lambda, so 343/0.7 = 490 which is correct. why did you set lambda = 2(L2-L1)? it works to get the correct final answer, but i don't know the logic behind it.
Because L2-L1 = 1/2 lambda because the difference between any 2 resonant lengths in a closed tube is 1/2lambda. So knowing that:
1/2lambda = L2-L1
lambda = 2(L2-L1)
ooohhhh ok. wow that's a pretty important rule - can't believe i didn't know that. Thanks for your help!
Yeah, you're right goodjob
Just didn't see that while typing it out! Hope it helped though
:-p
actually knowing [tex]\lambda[/tex]/4=L1
and 3[tex]\lambda[/tex]/4=L2
we can say (L2-L1)= 3[tex]\lambda[/tex]/4 - [tex]\lambda[/tex]/4
= 2[tex]\lambda[/tex]/4
=[tex]\lambda[/tex]/2
(L2-L1)=[tex]\lambda[/tex]/2
2(L2-L1)=[tex]\lambda[/tex] <--- shown
9K
31K
10K
