How Can You Derive the Formula for Curvature in Non-Arclength Parametrization?
  • Thread starter Thread starter MichaelT
    Curvature Proof
The problem involves deriving the formula for curvature in the context of a curve parametrized by a variable other than arc length. The original poster notes that the previous parts of the problem were based on arc length parametrization, but this part does not specify that, leading to the assumption that it is not parametrized by arc length.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to express curvature in terms of the derivatives of the curve and questions the relevance of their derived equation. They also inquire about the necessity of finding the norm of the second derivative.
  • One participant provides a hint involving a vector identity related to the cross product, suggesting that the original poster consider the orthogonality of certain vectors.
  • Another participant discusses the relationship between the norms of the vectors involved and expresses a need to connect their findings to the curvature formula.
The discussion is active, with participants providing hints and exploring relationships between the components of the curvature formula. There is a focus on understanding the implications of the vector identities and norms, but no consensus or resolution has been reached yet.
There is an underlying assumption that the curve is not parametrized by arc length, which may influence the approach to deriving the curvature formula. The original poster is also navigating the complexities of relating different derivatives and their norms.
MichaelT
If c is given in terms of some other parameter t and c'(t) is never zero, show that
k = ||c'(t) x c"(t)||/||c'(t)||3
The first two parts of this problem involved a path parametrized by arc length, but this part says nothing about that, so I assume that this path is not parametrized by arc length.
I have found that
T'(t) = c"(t) = [||c'(t)||2c"(t) - c'(t)(c'(t) dot c"(t))]/||c'(t)||3
I am having trouble figuring out how to relate the curvature to the equation
I can express the equation as the components so
F(x,y,z) = [(z"y'-y"z')2+(x"z'-x'z")2(y"x'-x'y")2]1/2/(x'2+y'2+z'2)3/2
Where should I go from here, and is the above equation useful at all? Do I need to find
||c"(t)|| as well (and is that even possible)?
What you have the numerator there is (c'(t).c'(t))*c''(t)-c'(t)(c'(t).c''(t)). There is a vector identity that tells you that that is the same as c'(t)x(c''(t)xc'(t)). When you take the norm of that note that c'(t) and c''(t)xc'(t) are orthogonal. So the sin(theta) in the cross product is one. Is that enough of a hint?
I am definitely getting there with this hint.
so I take the norm of c'(t) X (c"(t) X c'(t)) and get
||c'(t) X (c"(t) X c'(t))|| = ||c'(t)||* ||c"(t) X c'(t)||sin(theta) where theta = pi/2
so ||c'(t) X (c"(t) X c'(t))|| = ||c'(t)||* ||c"(t) X c'(t)||
Now I need to relate this to k = ||c"(t)|| correct? I have taken the norm of the numerator, but not of the denominator ||c'(t)||^3
Thanks for your help!
