Solve Resistance Problem: Parallel Resistors, Closed Switch & 1.2A Reading
  • Thread starter Thread starter prat
    Resistance
The discussion revolves around a circuit problem involving three parallel resistors with equal resistance and an ammeter reading of 1.2A when the switch is open. When the switch is closed, the total current will increase due to the parallel configuration of the resistors. The exact current reading when the switch is closed can be calculated using Ohm's Law and the principles of parallel circuits, specifically focusing on the total resistance and current distribution across the resistors.
  • Understanding of Ohm's Law
  • Knowledge of parallel resistor circuits
  • Familiarity with ammeter usage and readings
  • Basic circuit diagram interpretation skills
  • Study the calculation of total resistance in parallel circuits
  • Learn how to apply Ohm's Law in circuit analysis
  • Explore the behavior of current in parallel resistor configurations
  • Review circuit diagram representation and analysis techniques
Students studying electrical engineering, hobbyists working on circuit design, and anyone looking to understand the principles of current flow in parallel resistor circuits.
prat
if there is a circuit in which switch is open and ammeter reading is 1.2A THERE ARE THREE RESISTORS PARALLEL WHO HAVE SAME RESISTANCE.WHAT WILL BE THE CURRENT WHEN THE SWITCH IS CLOSED
Do you have any more information? Perhaps a diagram?
Also, show everyone what you have done so far.
  • · Replies 17 ·
