How can Nokia's radio wave-powered cell phone generate enough energy to operate?
  • Thread starter Thread starter cordius
    Power Receiver
The discussion revolves around the feasibility and mechanics of Nokia's development of a radio wave-powered cell phone, specifically focusing on how such a device could generate enough energy to operate. Participants explore antenna design, power extraction from radio waves, and the practicality of the technology.
  • One participant questions how a small antenna can pick up multiple frequencies and expresses interest in building one.
  • Another suggests that a Yagi antenna or a fractal antenna could be used for multi-frequency reception.
  • There is a discussion about the theoretical best receiver design, including the possibility of stacking antennas to capture more frequencies.
  • Concerns are raised about the actual power available from radio transmissions, with one participant stating that the power would be negligible unless near a strong transmitter.
  • Participants discuss the voltage required to extract power effectively, noting that it must exceed the Schottky diode drop of about 0.2V.
  • One participant mentions that crystal radios can operate without external power, suggesting that similar technology could potentially power low-voltage devices.
  • Another participant expresses skepticism about the viability of harvesting energy from random radio signals, citing the inverse square law that diminishes signal strength with distance.
  • There is mention of Nokia's announcement and skepticism about the credibility of the sources reporting on the technology.
  • One participant points out that capturing energy from localized sources, like RFID systems, may be more feasible than from random radio waves.
Participants express a mix of skepticism and curiosity regarding the technology. While some explore the potential for energy harvesting from radio waves, others argue that the actual power available is likely insufficient for practical use. No consensus is reached on the feasibility of the technology as described.
Participants note limitations regarding the assumptions about power availability from radio waves and the effectiveness of various antenna designs. The discussion reflects uncertainty about the practical implementation of the technology.
cordius
http://www.fastcompany.com/blog/ari...okia-developing-radio-wave-powered-cell-phone
Now, I am sure at least some of you have heard of this technology that Nokia is developing. It creates around 5 mW right now. My question is, how do you make an antenna that small pick up that many frequencies/wavelengths? What if I wanted to build one?
I apologize if any of this is a dumb question, my EET degree hasn't dabbled much in communications...at least not yet.
Welcome to the PF. You can make a multi-frequency, fairly broadband antenna with a Yagi with stepped length elements:
http://images.google.com/images?hl=en&source=hp&q=yagi+antenna&gbv=2&aq=f&oq=&aqi=g1
Or they may have used some other antenna shape. Maybe even a fractal antenna:
http://images.google.com/images?hl=en&source=hp&q=fractal+antenna&gbv=2&aq=f&oq=&aqi=
There are also variations in geometry to help make the antenna less directional.
Thank you, happy to be here :)
What would be the theoretically best receiver? To receive as many frequencies as they are trying to, could you put one antenna on front of another to catch both?
That said, does anyone know how much voltage is induced in a wire when it is struck by EM waves?
Good questions. To extract power, the antenna terminal voltage needs to be larger than a Schottky diode drop (about 0.2V for small powers) in peak value. I'll need to check my textbook tomorrow, but it would seem to be a moderately high power that is required in receive to get to that kind of terminal voltages in the 500MHz-fewGHz range.
And if you are trying to extract power from multiple bands, then yes, it would be optimal to use separate antennas and rectifying circuits, to eliminate phase issues that would cut down some on efficiency. I don't think the loss of efficiency is very large, though, so it could be that you just rectify the terminal output voltage from a broadband antenna.
Much as we all love the Internet it has the problem that anybody can say anything even if there is no basis for it at all.
IF you took all the radio transmissions reaching your house at anyone moment, how much power would there be? Absolutely ZERO unless you live under a transmitting tower for a radio station.
This is because signals on different frequencies cannot be in phase, so their net amplitude is zero or close to it.
So, even if you rectified the total mess of signals, even with a perfect diode, you would get nothing.
These radio signals are incredibly weak too. A "very strong" signal you might hear on a shortwave receiver is probably 50 uVolts at the antenna terminal of the receiver. That is 0.00005 Volts.
This is because there is an inverse square law that makes radio signals sharply decrease in amplitude as they move away from the source.
So, even if you tuned this one signal in and rectified it somehow, you would have an extremely small amount of power.
It takes serious power to work the transmitter of a cell phone. You could certainly get it from solar power but you won't get it from other radio transmissions.
Nokia is a big company and they have their own website. Would they really announce something like this through a website nobody has ever heard of? I checked their website and they were not announcing any such development at this stage, or probably ever.
What would a schematic look like, exactly? I've never worked with a Schottky diode before, but my research turns up that they are basically just really efficient diodes that drop around 220 mV. Crystal radios are able to run on their own power without being plugged in so...theoretically if I wished, I could light a low voltage set of LEDs or some other highly efficient lighting?
They aren't the only ones that published the story. I just liked their description.
http://www.technologyreview.com/communications/22764/
http://tech.yahoo.com/blogs/null/143945
http://news.cnet.com/8301-17938_105-10267006-1.html
Nokia announced it, and they are making it work somehow.
You will notice that the C-Net article is actually ridiculing the idea.
What they seem to be trying is to capture the RFID energy used at the entrance of libraries etc to detect illegal removal of books.
This is a very localised source of power, but at least it is better than trying to capture power from random shortwave transmissions. And it is a single frequency transmission, so some power is available.
It would be possible to have inductive loops built into desks so that you could charge a phone by just resting the phone above the loop. This would take a lot of hardware, but it could be done.
I think in the woman writing the article was trying to make a connection so people understand what radio waves are. Some people just don't know.
There must be a lot more energy available from the room lighting than from random radio pickup from the RFID device.
Calculators have been using this free energy for years. However a cell phone uses serious power whereas a calculator uses very little.
11K
