The Meaning of the Ideal Gas Equation: Vdp + pdV = 0
  • Context: Undergrad
  • Thread starter Thread starter quietrain
    Gas Ideal gas
The discussion revolves around the ideal gas equation and its implications, particularly focusing on the expression Vdp + pdV = 0 when temperature is held constant. Participants explore its mathematical derivation, physical meaning, and connections to concepts such as compressibility and energy conservation.
  • One participant states that if temperature is constant, then PV is also constant, leading to the derivative d(PV) = 0, which is derived using the product rule of calculus.
  • Another participant questions the physical meaning of the equation Vdp + pdV, relating it to compressibility and drawing parallels to momentum equations.
  • It is noted that compressibility can be derived from the ideal gas law without needing to manipulate the equation Vdp + pdV.
  • A participant distinguishes between the terms pdV and Vdp, suggesting that their equality is not inherently obvious and relates to specific contexts in work calculations.
  • One participant offers an interpretation that connects the equation to energy conservation, suggesting that energy lost through work must equal energy gained through heat flow at constant temperature.
Participants express varying interpretations of the meaning and implications of the equation Vdp + pdV. There is no consensus on its significance, and multiple competing views remain regarding its physical interpretation and mathematical manipulation.
Some assumptions regarding the ideal gas behavior and the conditions under which the equation holds are not explicitly stated. The discussion also reflects differing perspectives on the relationship between work, energy, and the ideal gas law.
quietrain
PV = nRT
why when T is constant,
Vdp + pdV = 0?
Science news on Phys.org
If T = const., then PV = const.
If we take the derivative of both sides with respect to "x" (which is any relevant variable), we obtain:
[tex]\frac{d}{dx}(PV) = 0[/tex]
where the right hand side is zero because the derivative of a constant is zero. Now, the product rule from differential calculus says that the left-hand side becomes:
[tex]P \frac {dV}{dx} + V\frac{dP}{dx} = 0[/tex]
oh. does it have any meaning?
because somehow, it is manipulated to become the compressibility of the gas. k = -1/v (dv/dp) = 1/p.
it reminds me of the momentum = mv which became mdv + vdm.
so does it mean anything the equation pdv + vdp ?
But you don't need to use that relation to get the compressibility. You only need to find the derivative [itex](\partial V / \partial P)_T[/itex] using the ideal gas law.
aren't they the same?
pdV is pressure times an infinitesmal change in volume while Vdp is volume times an infinitesmal change in pressure. There's no obvious reason why they should be equal aside from the derivation.
Since work is given by [tex]\int pdV[/tex] in some situations it may be more convenient to calculate [tex]\int Vdp[/tex]
Here's my interpretation of the meaning: if the temperature of the gas remains constant, then so does its total internal energy. If so, then this must mean that:
energy lost = energy gained.
-pdV = VdP
We can interpret PdV as the infinitesimal work done by the gas on its surroundings (a source of loss of internal energy if the work is positive). Similarly, we can interpret the term VdP as the internal energy gained through heat flow (heating a gas at constant volume will increase the pressure, which is proportional to the energy density). So, you could interpret this equation as saying that if the temperature (and therefore internal energy) of an ideal gas is to remain constant, then any energy loss by work done on the surroundings must be exactly balanced by energy gained through heat flow.
  • · Replies 35 ·
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 16 ·
