Stefan's Radiation Law with Boxes
  • Context: Undergrad
  • Thread starter Thread starter Fireworks
    Law Radiation
This discussion centers on the application of Stefan's radiation law in an experimental setup involving three boxes with different surface treatments: one white, one black, and one covered with plants. The experiment recorded temperature variations every 30 minutes, revealing that the white box maintained cooler temperatures than the black box. The formula used, Pnet = σAe(T^4 - TO^4), incorporates the Stefan-Boltzmann constant (5.6696 x 10^-8 W/m²∙K⁴) and emphasizes the role of emissivity in heat absorption and loss. The findings suggest that while all boxes receive equal sunlight, the emissivity and heat loss mechanisms significantly influence temperature outcomes.
  • Understanding of Stefan-Boltzmann law and its application in thermal physics.
  • Familiarity with emissivity and its impact on heat absorption and radiation.
  • Basic knowledge of thermodynamics, particularly heat transfer mechanisms (conduction, convection, radiation).
  • Experience with experimental data collection and analysis techniques.
  • Research the implications of emissivity on thermal performance in different materials.
  • Explore advanced applications of Stefan-Boltzmann law in real-world scenarios.
  • Investigate the effects of surface area and environmental factors on heat transfer rates.
  • Learn about the role of plant transpiration in temperature regulation and microclimates.
Students and researchers in physics, environmental science, and engineering, particularly those interested in thermal dynamics and heat transfer phenomena.
Fireworks
I performed my own experiment, with one roof of one box painted white, another black and a third covered with plants. Temperatures were recorded inside of the boxes every 30 minutes. How could Stefan's radiation law be used with the temperatures to reflect the white box having cooler temperatures then the black box?
I am trying to use Pnet = [tex]\sigma[/tex]Ae(T4 - TO4) ; where P is power, [tex]\sigma[/tex]is the Stefan-Boltzmann constant (5.6696 x 10 W/m2∙K4), A is surface area, e is the emissivity of the object, T is temperature of the object, and TO is the surrounding temperature.
Any suggestions on how to use Stefan's radiation law to support/explain my data?
Science news on Phys.org
I guess all the boxes receives the same amount of sunlight.
From the Stefan's Law you can tell that radiation heat loss is proportional to emissivity. On the other hand, the heat absorbed from sunlight is also proportional to emissivity. For steady temperature, heat absorbed = heat loss so you should expect all the boxes to reach the same temperature in the absence of other means of heat loss (e.g. when hung in a vacuum). The other means include conduction and convection which are independent of emissivity so a darker surface loses *comparatively* less heat through the other means, resulting in a higher temperature.
Plants can lose significant amount of heat through evaporation and larger surface area. I hope you are not required to justify why such factors are small compared with the low emissivity of the white surface. In extreme conditions (low light, high ambient temperature), plants can be cooler than the surrounding!
Wai Wong
  • · Replies 20 ·
  • · Replies 29 ·
