How do I solve this problem without knowing the time?
  • Thread starter Thread starter Player7900
    Ball
The problem involves a ball thrown straight upward with an initial velocity of 50 m/s. Participants are discussing how to determine the time it takes for the ball to stop rising, the maximum height reached, and the acceleration during this motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore kinematic equations and the relationship between initial velocity, final velocity, and acceleration. Some question how to apply these equations without knowing the time or height initially.
Several participants have suggested using energy conservation principles and kinematic equations to relate the variables. There is ongoing exploration of how to derive time from the known initial velocity and other parameters, with no explicit consensus reached.
Participants note the assumption of no air resistance and the relevance of initial velocity and gravity in solving the problem. There is also mention of the challenge of working without a calculator and the order of questions in the homework statement.
Player7900
Hello everyone. I'm sorry for asking such basic questions without offering much in a solution attempt, but the problem is - I have no idea how to answer them! I'm obviously a non-scientist and my math skills aren't so great either. But I would like if someone could simply show me HOW to answer these questions, so I could find the answers myself:
"A ball is thrown straight upward at a velocity of 50 m/s:
(1) How long will it take for the ball to stop rising?
(2) How far up has the ball traveled in this time?
(3) What is the ball's acceleration during this time?"
d = 1/2gt2
I know how to answer #2 if the ball is in freefall, but I don't know what to do if the ball starts at an upward velocity. Ditto for #1 and #3...
Your initial vertical velocity is 50m/s
Right, that is given in the question. I'm not sure what to do with that...
In your kinematic equations you have
v=u+at
v2=u2+2ad
d=ut+1/2at2
u= initial velocity.
At the highest point, what is the final vertical velocity equal to?
v=u+at
v2=u2+2ad
d=ut+1/2at2
0 m/s --- So what would I do with that number? (If I should know by now, again I must apologize as I haven't used anything but basic math in years)
The only two equations you need are
1/2mv^2 kinetic
and
mgh gravitational
if the ball has reached it's max height then there is no kinetic so if you make these equations equal to each other, the masses will cancel out, you no your speed v, you no gravity g, all you need to account for is height h, which is simple rearranging
1/2mv^2 kinetic
and
mgh gravitational
I don't think mass needs to be accounted for, for this question. The question assumes there is no air resistance, and I guess the only relevant factors in figuring out the answers are initial velocity and gravity.
For the first formula I get: 1/2(50)^2 = 1250 J
So, what can I do with that number? Should it help me figure out the height?
Set that formula equal to the gravatational potential equation which is mgh but it's like I said, m is irrelevant and u do no g, all you need is h
1/2mv^2=mgh
work from there
Edgar92 said:
1/2mv^2=mgh
work from there
1250=gh
1250=(9.8)(h)
1250/9.8=h
h=127.5m
Is that correct? If so, how then would I get the time to reach maximum height?
I don't have a calculator but the equation is right
height is equal to distance
use the equation d=v*t since you know 2 of the 3 variables
t=d/v try it and you should be done
Be sure to post when your done so I know when to stop lol
127.5/50=t
t=2.55
The last question is "What is the ball's acceleration during this time?" - What should I do to figure that out?
Also, is there a way to figure out (t) before figuring out (d)? I ask because that question that asks for (t) comes first...
a=v/t
now that you have t and have v aswell, just sub in the appropriate values and you are done. I'm done for the day but that should be enough to finish the rest of this question
If anyone else could offer one last bit of advice:
Is there a formula that I can use to find (t) before finding (h), if all that is known is the initial velocity?
The kinematic equations
v=u+at
v2=u2+2ad
d=ut+1/2at2
v=final velocity
At the highest point, the final vertical velocity is zero.
  • · Replies 19 ·
