Engine Power Specification: How & Why Max Power & Torque at Certain Speeds?
The discussion revolves around the specification of engine power and torque, particularly why maximum power and torque are reported at certain engine speeds. Participants explore the relationship between engine speed, torque, and the factors influencing these specifications, including design limitations and airflow dynamics.
  • Some participants inquire whether the question pertains to a specific engine or engines in general.
  • It is noted that power is generally quoted at the engine speed where it peaks, which may be limited by design or physical constraints.
  • Torque is also typically reported at its peak engine speed, with some participants explaining that power is the product of torque and RPM.
  • One participant discusses how the combustion of fuel and air generates torque, but airflow limitations through intake and exhaust runners can restrict torque at higher RPMs.
  • Another participant emphasizes the importance of runner size and air velocity in cylinder filling, suggesting that larger runners can lead to sluggish flow and that camshaft events significantly influence engine performance.
Participants express various viewpoints on the factors affecting engine performance, particularly regarding airflow and runner size. There is no consensus on the optimal design parameters, and the discussion reflects multiple competing perspectives on how these factors interact.
Some claims about airflow dynamics and engine design are made without fully resolving the complexities involved, such as the balance between runner size and air velocity, as well as the impact of camshaft selection on engine performance.
satya251166
How the specification of an engine power done. Why its said power and torque max at some speeds. I am searching for the answer for a long time. Can someone help me..
Welcome to PF!
Are you asking in general or for a specific engine?
Anyway, most engines which produces power by turning an axle are usually characterized by a relationship between angular speed and torque. If you search for "engine speed torque diagram" you should be able to find some useful explanations, like for instance [1].
If such explanations do not help you understand then try explain what it is you don't understand. The best would be if you could point to some calculation (from a book or web) and say which part of it that eludes you.[1] http://lancet.mit.edu/motors/motors3.html
The engine gets its torque from the combustion of fuel and air. Power is the product of torque and rpm. In theory, the torque should be constant no matter the rpm of the engine, if the quantity of air and fuel is the same. But the air has to go trough the intake and exhaust runners to get in and out the cylinder, which size is greatly dependent on the cylinder bore. The cross-sectional area of these runners will determine the maximum quantity of air that can get in the cylinder. At a certain rpm, the runners will create such a restriction that there won't be enough air to fill the cylinder to give the same torque as the one from lower rpm.
Are you asking why the specs are given at particular engine speeds?
Power is generally quoted at the engine speed at which it peaks (or its rated power). This is the maximum power produced by the engine and is either limited by design (such as in the case of most automotive engines) or by a physical limitation on some component or system.
Torque is usually quoted at the engine speed at which that peaks.
Filip Larsen said:
Welcome to PF!
Thank you.I will check it out
This really satisfies me . Thank you
We should dismantle any thought here that has/could have moved towards the bigger is better theory when it comes to heads, intakes, valves etc.
The runner's CC amount does have influence on cylinder filling, but, depending on your application your air velocities are more important than the runner area to a point, sure the higher the rpm range you want to operate at or the higher horsepower goal, you need larger runners. Too big is bad because of 'sluggish' flow happening, finding the right runner size is much needed. Camshaft events immensely dictate the cylinder filling action in correlation to the velocity of flow throughout the induction manifold and intake & exhaust ports. You could have great flowing heads, but, have a terrible running engine simply from a bad camshaft choice or slow air flow velocities in general.
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 17 ·
