Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   I'm having trouble finding the integral using u-substitution. (http://www.physicsforums.com/showthread.php?t=505318)
nerdy_hottie Jun8-11 01:57 PM
I have to integrate using u-substitution (probably).
Ex. 1 Integrate (sin^4x)/(cos^6x)dx
2. Integrate (2x)/(sqrt(e^(2x^2)-1))dx
3. Integrate (cos^-1x)/(sqrt(1-x^2))dx
Thank you !
2. Relevant equations
I do not want the solutions. I just need to be pointed in the right direction (i.e. I need you to help me start off)
**It should be noted that I am doing a calculus II course (Integral Calc, mostly) in university, so it's not very advanced integrals that I'm doing. Basically what I know is how to integrate using u-substitution, and I know the integrals for the inverse trig functions (which is supposed to be relevant to examples 2 & 3), and that's what information I have to work with.
**It should also be noted that I may just not know how to rewrite the equations before I can integrate them. I have trouble 'seeing through' the equation and automatically knowing which way I'm going to solve it.
3. The attempt at a solution
Ex. 1 I tried rewriting the equation using trig identities, e.g. (1-cos(x))/(1-sin(x))^3. I found this got me nowhere.
I also tried rewriting it is (sin^4)(x)/(cos^4)(x)*1/cos(x), and rewriting and rewriting until I ended up with a big mess, so that got me nowhere as well.
2. Here's my dilemma:
-if I substitute e^2x for u, I end up needing an e to the power in my numerator, so that doesn't work out.
-if I instead substitute 2x^2 for u, I end up with the e to the power of u on the bottom and I don't have a formula for that.
3. I have no ideas on this one.
Mark44 Jun8-11 02:07 PM
Re: I'm having trouble finding the integral using u-substitution.
Quote:
Quote by nerdy_hottie (Post 3346015)
Thank you !
This is the right approach, but you have an error. Your integrand is equal to tan4(x)sec2(x). That should suggest a pretty obvious substitution.
I don't have any ideas just yet, but I'll think about this one.
If u = cos-1(x), what is du?
BTW, welcome to Physics Forums!
SteamKing Jun8-11 03:42 PM
For example 2, rewrite the integrand to remove the sqrt in the denominator, that is, express 1/sqrt(e^(2*x^2)-1) using the appropriate exponent. After doing this, see if the factor 2x would be useful in integration by parts.
SteamKing Jun8-11 03:44 PM
Quote:
Quote by SteamKing (Post 3346172)
Check that last suggestion.
See if the factor 2x would be useful in a u-substitution integration.
nerdy_hottie Jun8-11 05:43 PM
Thanks all, but I still cannot find the solution to the second example.
I let u=2x, so du=2dx
Since the x is is still in the numerator, I say that also, x=u/2
So I fill this in and I get Integral of (u/2)(1/(sqrt((e^u)-1))du
I have not yet learned to do integration by parts, by the way.
vela Jun8-11 06:06 PM
The argument of the exponential has an x2 in it, right? So try u=x2 to try simplify that a bit. That's where you find the factor of 2x comes in handy.
Then you might try a substitution like v=eu and see where that gets you. A lot of this you figure out by trial and error. As you do more problems, you'll start to get a feel for what works and what doesn't.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
