Flame Treatment Machine for Automotive Parts: Tips for Choosing the Right Burner
  • Thread starter Thread starter 68rs327
    Machine Treatment
The discussion centers on the fabrication of a Flame Treatment Machine for automotive parts to enhance adhesive bonding by improving surface dynes. The user, Matt, is considering using a burner similar to those in Ventless Gas Fireplaces, with a specific requirement for the flame to flow downward onto the parts on a mesh conveyor system. Key recommendations include consulting a burner manufacturer, such as Bloom Engineering, to ensure safe and effective flame treatment. The process requires only a few seconds of exposure to achieve the desired results.
  • Understanding of Flame Treatment processes
  • Knowledge of adhesive bonding techniques in automotive applications
  • Familiarity with conveyor systems, specifically mesh conveyors
  • Basic principles of burner operation and safety
  • Research different types of burners suitable for flame treatment, focusing on downward flame flow
  • Investigate the specifications and safety features of Bloom Engineering burners
  • Explore the impact of dynes on adhesive performance in automotive applications
  • Learn about the design and operation of mesh conveyor systems for industrial applications
This discussion is beneficial for automotive suppliers, engineers involved in adhesive applications, and professionals designing flame treatment systems for improved bonding processes.
68rs327
Flame Treatment Machine, need help...
I work for a automotive supplier company. I am needing to fabricate a Flame Treatment Machine to Flame Treat the Parts before applying a adhesive shim. The Flame Treatment Improves the Dynes of the parts for better adhersion of the shim. I am fabricating a Mesh
Conveyor System. I am thinking of using a Burner like those found on Ventless Gas Fireplaces to use as the flame source. My only concerns are that the flame needs to flow Down onto the parts and I was concerned the flame will flow UP from the Burner.
The parts would be placed on the wire mesh conveyor and would pass under the flame as the conveyor moves forward to achieve Flame Treatment. It only takes a few seconds under the flame to get the desired dynes. I need ideas on the Flame Burner and What would be Best to Use to have the flame blowing Down.
You should consult a burner manufacturer, like Bloom before you end up burning down your house and yourself.
http://www.bloomeng.com/
Thanks
Matt
  • · Replies 24 ·
  • · Replies 17 ·
19K
