The origin of dy = f'(c)dx in differentials
The origin of the equation dy = f'(c)dx is derived from the limit definition of the derivative, where dy represents an infinitesimal change in the function f at a point c, and dx represents an infinitesimal change in the variable x. The relationship is established through the limit process: lim(Δx → 0) (Δy/Δx) = f'(c), which leads to the notation dy/dx. This notation signifies the slope of the tangent line to the curve at the point c, emphasizing that dy is not a fraction but a representation of the derivative. The discussion clarifies that while Δy represents the actual change in the function, dy serves as an approximation that becomes increasingly accurate as Δx approaches zero.
  • Understanding of calculus concepts, specifically limits and derivatives.
  • Familiarity with the notation of differentials and their applications.
  • Knowledge of the function behavior around a point, particularly continuity and differentiability.
  • Graphical interpretation of functions and their tangent lines.
  • Study the formal definition of the derivative using limits in calculus.
  • Explore the concept of differentiability and its implications for function behavior.
  • Learn about the applications of differentials in real-world problems, such as linear approximations.
  • Investigate higher-dimensional differentials and their mathematical significance.
Students of calculus, mathematics educators, and anyone seeking to deepen their understanding of derivatives and their applications in real analysis.
vanmaiden
If you have a point at x = c and a function f(x), then I know Δy = f(c + Δx) - f(c).
Also, dy = f'(c)dx. However, I am uncertain of the origin of dy = f'(x)dx.
I want to say:
f(c + Δx) - f(c) = f'(c)(x-c) was simplified to dy = f'(c)dx
where f(c + Δx) - f(c) = dy
(x-c) = dx
But that would result in Δy = f'(c)dx and Δy > dy. Hence, it is...or should be wrong. Could anybody clairify the origin of dy = f'(c)dx for me?
Im the problem, actually.
Also, in the problem! lol
Actually, the trick is to look at the ratio of the changes, [itex]\frac{\Delta y}{\Delta x}[/itex]. You can represent this on the graph of the curve as the average change of the function, or the slope of the straight line approximation on that small interval.
Initially it may seem strange to use a straight line approximation, but if you think about it for a minute, you will see that it's not such a bad idea because the smaller you make [itex]\Delta x[/itex], the better the straight line resembles the graph around x = c. In fact, the line you get becomes closer and closer to the tangent line of the graph at x = c. So it makes sense to try and do this analytically, for which we can use a limit: we consider
[tex]\lim_{\Delta x \to 0} \frac{\Delta y}{\Delta x}[/tex]
And to make the dependence of the numerator explicit,
[tex]\lim_{h \to 0} \frac{f(c + h) - f(c)}{h}[/tex]
where I called [itex]\Delta x = h[/itex].
This number, if the limit exists, actually is the slope of the tangent line. Note that is no longer a real quotient, it's just the limit of a quotient. So we can invent the notation [itex]\frac{dy}{dx}[/itex] or [itex]\frac{df(x)}{dx}[/itex] or, if you want to have c in there somewhere,
[tex]\left. \frac{df(x)}{dx} \right|_{x = c}[/tex]
The safest way is now to think of it as just that, notation, and nothing else. Again, df/dx is not really a fraction anymore, so if df/dx = 3 that merely means that the slope of f at x is equal to 3. You shouldn't allow yourself to write things like df = 3 dx. If you can't resist the temptation, then consider writing f'(c) instead :-)
Just as an after-thought, it is true (for continuous functions) that if [itex]\lim_{\Delta x \to 0} \frac{\Delta y}{\Delta x} = f'(c)[/itex], then
[tex]\lim_{\Delta x \to 0} \Delta y = \lim_{\Delta x \to 0} f'(c) \Delta x[/tex]
because f'(c) is just a fixed number (which I denote by f'(c), or you could call it a or L) and if you plug in [itex]\Delta y = f(c) - f(c + \Delta x)[/itex] you will find that both sides of the expression are equal to 0. So in that sense, you can split out the fraction, but it doesn't give you anything useful.
Basically, you set y=f(x); then, Δy=f(c+Δx)-f(c) is the actual change in the value of f from
c+Δx to c. If f is differentiable at c, then the change in values of f can be approximated at any level of precision (in a strict δ-ε sense) by a linear function . This approximation is called dy, and is given by dy=f'(x)dx (or a related expression in higher dimensions), so that, limitΔx→0Δy=dy , i.e., the change in the values of a differentiable function can be modeled with indefinite precision by a linear function; this is actually too, the actual definition of differentiability: f is differentiable if the change of values of f can be modeled locally (in a 'hood of a point where f is differentiable.) by a linear function L; this L is called the differential.
  • · Replies 21 ·
