Byron Nuclear Gen Station Backup Cooling Pumps
The discussion revolves around the backup cooling pumps at the Byron Nuclear Generating Station, particularly in the context of a recent power loss incident. Participants explore the implications of the backup pumps' capacity, the operational status of the cooling systems, and the safety measures taken during the incident.
  • One participant inquires about whether the backup water pumps at Byron NGS have been upgraded and questions if the plant is currently using the main or backup cooling pumps.
  • Another participant provides details about a recent shutdown of Unit 2 due to a loss of off-site power, noting that steam was vented to reduce pressure and that diesel generators were activated to supply power.
  • Concerns are raised about the adequacy of the backup cooling pumps, referencing NRC statements that they were deemed too small for emergency cooling after the Fukushima incident.
  • Some participants express relief that officials claim there is no danger to the public or plant operators, while questioning the rationale behind worker evacuations during the incident.
  • There are speculations about the reasons for evacuations, with one participant suggesting it may be a precautionary measure rather than an indication of danger.
  • Another participant mentions that the NRC will investigate the power loss incident and review the plant staff's response.
Participants express varying levels of concern regarding the safety measures taken during the incident and the adequacy of the backup cooling systems. There is no consensus on the implications of the backup pump capacity or the necessity of evacuations, indicating ongoing uncertainty and debate.
Participants reference specific incidents and statements from regulatory bodies, but there are unresolved questions about the adequacy of the backup systems and the rationale for safety protocols during the incident.
swl
Do any of you know if the backup water pumps have been upgraded at the Byron NGS?
Also, is the plant currently using the main cooling pumps, or the backup pumps?
Last year after the Fukushima triple meltdown, the NRC told the Exelon that the backup cooling pumps at Byron were too small to cool the reactor in an emergency, and after waffling back and forth on the issue, the operator, Exelon, decided the pumps were indeed too small.
So, are the undersized pumps the reason for their decision to release radioactive steam into the atmosphere? Or is this the normal operating procedure in response to loss of offsite power?
Thanks for any expert guidance.
AP said:
BYRON, Ill. (AP) — A nuclear reactor at a northern Illinois plant shut down Monday after losing power, and steam was being vented to reduce pressure, according to officials from Exelon Nuclear and federal regulators.
Unit 2 at Byron Generating Station shut down around 10:18 a.m., after losing power from an off-site source, Exelon officials said. Diesel generators began supplying power to the plant equipment and operators began releasing steam from the non-nuclear side of the plant to help cool the reactor, officials said.
Even though the turbine is not turning to produce electricity, "you still need to cool the equipment." said U.S. Nuclear Regulatory Commission spokeswoman Viktoria Mitlyng. Releasing steam helps "take away some of that energy still being produced by nuclear reaction but that doesn't have anywhere to go now."
The steam contains low levels of radioactive tritium, but the levels are safe for workers and the public, federal and plant officials said.
Source: http://www.newstrib.com/articles/news/nci/default.asp?article=32125
The venting comes from the secondary side, and the apparently the plant is designed to do just that. The coolant in the secondary loop may contain some tritium from the primary coolant side, either from leaks or from the fact that hydrogen diffuses in metals from hotter to cooler.
Venting steam is a quick way to remove heat from the primary system. It appears unit 2 was running at full power, as was Unit 1, when it tripped. The current cycle of Unit 2 began Oct 10, 2011.
I am pleased to read that there is no danger to the public or plant operators.
Any ideas why http://www.nwherald.com/2012/01/30/power-loss-shuts-down-byron-nuclear-plant-unit-public-in-no-danger/asepmmg/ if there was no danger?
Could the radiation have been more intense near the plant, or could it have been to prevent hearing damage from the sound of the steam release?
"Any ideas why "Workers were evacuated" if there was no danger?""
my GUESS is it's innocuous, like a fire alarm went off or the office building went dark when offsite power through that transformer was lost..
were there a release there'd have been notification to public agencies.
From the cited source, "Workers were evacuated and Byron and several other area fire departments were on stand by at the scene as precautionary measures, . . . "
I imagine that workers in affected areas were removed as a precaution while the plant was being shutdown.
Meanwhile the NRC will investigate why the plant lost offsite power, and I expect they will review the response of the plant staff in managing the shutdown.
http://www.nrc.gov/reading-rm/doc-collections/news/2012/12-005.iii.pdf
  • · Replies 52 ·
11K
11K
  • · Replies 27 ·
11K
