Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Differential Equations (http://www.physicsforums.com/forumdisplay.php?f=74)
-   -   Volume flow rate DE - Help needed (http://www.physicsforums.com/showthread.php?t=576126)
ryancalif Feb9-12 11:45 PM
Hi all,
So I've got a fairly straight forward problem to solve here regarding flow rate out of a tank with uniform cross-sectional area. I am treating this is a volumetric flow problem since there is assumed to be volume flow out of the tank, and volume flow into the tank.
I have two Qout terms (one out of a hole in the bottom of the tank, and one from fluid consumed by an engine), as well as one Qin term (via a pump feeding fluid into the tank at a constant rate).
Qouthole (Qh) = a*C*sqrt(2*g*z)
Qoutengine (Qe) = constant
Qin (Qi) = constant
NOTE: a = exit hole area
C = energy loss coefficient
g = gravity
z = head height in tank
My DE looks like:
-A*(dh/dt) = Qh - Qi + Qe
Separating the terms and solving for time by integrating h from Hi to Hf and t from 0 to T, I get this...
((a*C)/A)*sqrt(2*g)*(2/3)*((Hf^(3/2))-(Hi^(3/2))) = (1/A)q*t
I combined the Qi and Qe terms early on since they are constants (easier to integrate), therefore, q in the above equation equals Qi-Qf.
The problem is, solving for t eliminates the tank cross-sectional area (A) since it is divided out.
I feel confident with my general equation, but may have made a mistake somewhere in solving for t. Any help would be GREATLY appreciated! Thank you
coelho Feb11-12 04:49 AM
Re: Volume flow rate DE - Help needed
Could you outline how did you arrive at the expression you found after integrating?
ryancalif Feb12-12 10:46 AM
Quote:
Quote by coelho (Post 3757814)
I found one (stupid) mistake I made in my original equation (divided out the Qleak term rather than adding it to the other side). So ignore that equation... Below is how I arrived at the new equation, and this one still has a problem.
Qleak = a*C*sqrt(2*g*h)
Qi = constant
Qe = constant
integrate dH from Hi to Hf
integrate dt from 0 to T
1. -A * (dH/dt) = Qleak - Qi + Qe
2. ... simplify by combining constants... Qi + Qe = Qtot
3. dH = (-Qleak/A + Qtot/A)dt
4. dH = 1/A*(-Qleak + Qtot)dt
5. (A*dH) / (-Qleak + Qtot) = dt
6. int((A*dH) / (-Qleak + Qtot)) = int(dt)
7. ... integrate dt from 0 to T
8. int((A*dH) / (-Qleak + Qtot)) = T
This is where I stopped since I could not find an easy way to integrate the left side. The basic form of the integral would be: dH/(h^1/2 + constant)
Any tips on where I may have gone wrong, or how to solve that integral would be appreciated! Thanks
coelho Feb13-12 02:16 PM
Quote:
Quote by ryancalif (Post 3759823)
Are H and h the same variable, or related in some way?
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
