Mike_In_Plano said:
I wouldn't say modern digital design is easy, I don't attempt it, and I stand amazed at a few people who do. None of them could say much about analog or RF, but they know the means and methods of their trade.
It's easy to build a counter, it's more interesting to interface DDR memory. It's also pretty challenging to build equipment that meets FCC part B on emissions, or can get through ESD testing. For that matter, things get pretty interesting when you fail to perform your timing analysis and equipment fails.
So, the same rules apply as with any trade: Get the basics at school and find a job that can train you.
The blue color part is analog in every sense, that's exactly what I refer to that a lot of them don't know how to do it. I spent years designing digital electronics, including Micro-processors boards, embedded system, Firewire, USB, FPGAs etc. They are easy if you don't deal with high speed end of things where it is...again analog. Digital design require a lot of reading, learning how to program the VLSI chips. But they are all very easy to understand. You don't get stuck like in analog particular as speed goes up.
Digital design in certain ways similar to programming, it is so easy to learn. You learn the first language and it will take you maybe two weeks to learn another language to get started. But it is complex and a lot of headache to trouble shoot...nothing hard, just a lot of trouble. Digital design has a lot of signal to keep track of, documentation has to be good. No one signal is that hard, but you have a whole lot of them to keep track.
If you are into computer and digital design, it might take you a few months and you'll have the basics of it. But it'll take years to learn analog, RF. There is no comparison. As a person that spent years designing both, digital design cannot even hold candle to analog design when come to degree of difficulty. Put it this way, I started out in digital, only take me a little over a year from first learning digital electronics to be a full blown design engineer designing and programming an Intel 8085 based system. That's how I started my career, what do I know about electronics and digital electronics were so slow you really don't need to know much electronics.
Look at how many kids playing around digital and everyone design a little things. Not as much as programming as those are even easier. And yes, I was almost a full blown programmer as I programed the embedded system in the early years. You'll find 10 times more digital engineer than analog...why?...most got stuck in analog, EM. I talked to quite a few EE, they barely creep through EM and so glad they got through it.
Also, problem with digital design, your knowledge can be obsoleted fast. I was so good in the early 8080 system, I can write long programs in machine language...just keep typing in hex numbers! Then 8080 was gone, then I learned 68000 16 bits, gone! 10 years ago, I learned Firewire, all the PHI, Link layers etc. ...Gone! All those knowledge don't mean a thing anymore. BUT we use transistors 50 years ago, we use op-amp 30 years ago...we still use every bit of it. I am currently helping two people here on transimpedance amplifiers...it is all op-amp theory mostly learn in the late 70s and early 80s.
Yes, timing diagram are the hardest, I draw full blown timing diagram looking a the min and max prop delay to make sure they come together. You'll be surprised how many so called digital engineer never draw timing diagram! This is really the necessary evil of digital to guaranty reliable design. I even put a simple timing diagram drawing as part of the test when I hire engineer or technician. You'll be surprised how many fail. Just two D flip flop one as divided by two and one is a pipeline. A lot of them can't even do it. If they fail, the interview ended.
