Proton moving in a magnetic field
The problem involves a proton moving through a uniform magnetic field, with specific parameters given for mass, charge, speed, and magnetic field strength. The objective is to determine the time required for the proton to exit the magnetic field after completing a semi-circular path.
  • Participants discuss the calculation of the radius of the proton's path using the equation qvB = mv²/R and the implications of the magnetic field's direction relative to the proton's velocity. There are attempts to clarify the relationship between the radius and the time taken to traverse the semi-circle.
The discussion includes various attempts to calculate the radius and time, with some participants expressing uncertainty about their results. There is acknowledgment of potential issues with rounding and significant figures affecting the answers provided. Multiple interpretations of the problem and calculations are being explored without a clear consensus.
Participants note discrepancies in their answers and the feedback from an online homework system, suggesting that the system may have specific requirements for precision or formatting that are not immediately clear.
erodger
A proton (mass= 1.67×10-27 kg, charge= 1.6×10-19 C) traveling with speed 1×106 m/s enters a region of space containing a uniform magnetic field of 1.2 T.
The magnetic field is coming out of the screen.
What is the time t required for the proton to re-emerge into the field-free region?
qvB = mv2/R
I begin by solving for R using the above equation:
R= (mv)/(qB)
Since the proton moves in and then back out it completes a semi-circle. The distance traveled is then πR as it is half of the circumference of a circle.
The velocity does not change for the entire distance traveled so dividing distance by velocity should give me the time.
This comes out as incorrect though. I am unsure as to what I am doing wrong.
in what direction is the magnetic field pointed relative to the initial velocity of the proton?
Oh sorry, I edited the post. It is coming out of the screen. So it is perpendicular to its motion which means it will create a net force on the proton and cause it to undergo the circular motion.
ah, okay. Well, what did you get for your time?
Well the question involved some steps and one of the steps was to find the radius. It continued to tell me I am wrong. I decided to stop using that and work on it my own using my method and I managed to come up with the correct answer, which just involved me to not round to 2 sig figs but add on more decimal digits. My answer was 2.73*10^(-8). Before I was just putting in 2.7*10^(-8).
Thanks for trying to help.
what did you get for your radius?
huh, actually that's the same time I got.
I got 8.698*10^(-3) for my radius. The computer kept telling me it was incorrect but I managed to get the right answer with this value so I do not know what is wrong...
so the time you got was correct, but the radius is not? Maybe it wants radius in terms of some unit like cm?
No it was asking for metres which is what my answer is in.
interesting... I don't know what to tell you :(
did you try the same thing with what you did with time? Try changing the number of decimal points, or how you round your numbers when you solve for it.Sometimes I have these same problems with online homework things. They usually accept answers within a certain range of the correct answer, but can be really stubborn sometimes :P
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 26 ·
