Effective thermal conductivity of sintered bronze
The effective thermal conductivity of sintered bronze, particularly in self-oiled sliding bearings like Oilite, is approximately 80-85% that of dense copper alloys such as tin bronze. Sintered bronze typically has a density range of 6.0-7.4 g/cc, while the theoretical density for 90/10 bronze is 8.75 g/cc. The presence of oil in the pores of sintered bronze also influences thermal conductivity, necessitating consideration of both the material density and oil type. Comprehensive thermal property data can be found in the TPPC series, though its current status is uncertain.
  • Understanding of thermal conductivity principles
  • Familiarity with sintered materials and their properties
  • Knowledge of density measurements in materials science
  • Basic concepts of self-lubricating bearings
  • Research the TPPC data series for thermal properties of alloys
  • Investigate the impact of oil types on thermal conductivity in sintered bronze
  • Explore density variations in sintered bronze and their effects on thermal performance
  • Examine historical data or graphs related to thermal conductivity of sintered materials
Materials scientists, mechanical engineers, and professionals involved in the design and application of self-lubricating bearings will benefit from this discussion.
vprantan
Hi
I've been trying to find effective thermal conductivity of sintered bronze, especially of that used in self-oiled sliding bearings (like Oilite). I need it to know how much less it is compared to dense copper alloys, eg. tin bronze.
So far my search has proven fruitless. It seems that sintered bronze manufacturers do not measure thermal conductivity at all, whereas for dense material it is normally stated.
Any help here?
The TPPC data series is quite comprehensive for thermal property data on common alloys. I'm not sure if it's been kept up to date. Purdue used to publish it, Touloukian was the editor if I recall.
The problem with what you are asking is there is to many variables in the material to give you a definite answer. The thermal conductivity will be proportional to the density of the material. The general sintered bronze material has a range of density from 6.0-7.4 g/cc the theoretical density for 90/10 bronze is 8.75g/cc. This mean that when not impregnated with oil the thermal conductivity will be in an exponential approaching the full density value based on density. Next because of the oil in the pores will conduct heat also this will need to be taken into account and the variables in the effective filling of the pores as well as the oil that is used. If you are looking for ballpark numbers I would put it at 80-85% the thermal conductivity of the wrought bronze material as standard oillite is an SAE841 (6.4-6.8 g/cc). I will look to see if there is any graphs that might have been developed in years past.
  • · Replies 0 ·
11K
  • · Replies 19 ·
11K
