How Does a Hollow Conducting Sphere Affect Internal and External Charges?
The discussion revolves around the effects of a hollow conducting sphere on internal and external charges, specifically focusing on a positive charge placed at the center of the sphere and another positive charge located outside the sphere. Participants explore the implications of charge induction and electric fields in this context.
  • Participants discuss the behavior of electric fields within and outside the hollow conducting sphere, questioning how the presence of charges affects the distribution of induced charges on the sphere's surfaces. There is consideration of the net electric forces acting on each charge and the implications of charge induction.
The conversation is ongoing, with various interpretations being explored regarding the effects of the charges on each other and the resulting electric fields. Some participants suggest that the charge inside the sphere does not experience a net force, while others raise questions about the influence of the external charge on the sphere's surface charge distribution.
Participants are navigating assumptions about the behavior of electric fields in conductors and the implications of charge induction, with some uncertainty regarding the interactions between the internal and external charges.
IWantToLearn
A hollow, conducting sphere is initially uncharged. A positive charge, +q1, is placed inside the sphere (at the center). Then, a second positive charge, +q2, is placed near the sphere but outside it.
Which of the following statements describes the net electric force on each charge?
1-There is a net electric force on +q2 but not on +q1.
2-There is a net electric force on +q1 but not on +q2.
3-Both charges are acted on by a net electric force with the same magnitude and in the same direction.
4-Both charges are acted on by a net electric force with the same magnitude but in opposite directions.
5-There is no net electric force on either charge.
Attempt at a solution
I know that for a charged hollow spherical conductor, the charge is distributed on both the inner and outer surface of the conductor, and the net electric field in the material of the conductor is zero, also the net electric field inside the cavity is zero, and the net eelectric field in a point close to the outer surface is δ/ε0
but in this case there is a point charge at the center of the cavity, and the net electric field inside the cavity must has a nonzero value (due to the point charge).
i thought that both of the charges may cause the spherical conductor to be charged through induction, so the electric field due its charge inside the cavity is zero, and hence choice (1) will be relevant, but i am not sure.
i thought also that if the spherical conductor will remain uncharged, so there will not be a charge distribution in its surface, and the only remaining thing is the coulomb force between the two charges acting on each other, so choice (4) will be relevant.
please help
The charge at the center of the sphere will induce an equal and opposite charge on the inside of the conducting sphere and a equal and same charge on the outside of the sphere.
So what does that tell you?
if so, then the charge at the center will not be affected by the electric field of the induced charge distribution on the inner surface, cause the field inside the cavity is zero,
and the charge outside will be affected by the electric field of the induced charge distribution on the outer surface, if this is the case then choice (1) is the answer
But wait a minute, why not the charge outside the sphere induce a charge distribution on the the sphere similar way to the charge distribution induced by the inner charge
if this is true, then we will have a complex charge distribution, and i can't tell exactly about the force
the charge on the inside the sphere is positive so its field lines will be emitted radially outwards to the negatively charged sphere. There is a field inside the sphere from the positively charged particle
there will be zero force on the particle inside the sphere
Since a positive charge is induced on the outside of the sphere the charge outside the sphere will experience a force
again why not the charge outside the sphere causes an induced electric charge distribution on the outer surface, so we have two overlapped charge distributions on the hollow sphere, one due to the inner charge and one due to the outer charge.
by the way the electric field at the center must be zero, and hence the force, so there is no force affecting the charge in the center.
  • · Replies 21 ·
