Angle for SHM(Simple pendulum)
  • Context: Undergrad
  • Thread starter Thread starter shayaan_musta
    Angle Pendulum
The discussion revolves around the necessity of using radians instead of degrees in the context of simple harmonic motion (SHM) for a simple pendulum. Participants explore the implications of using different angular measurements in physics equations.
  • Technical explanation, Conceptual clarification, Debate/contested
  • Some participants assert that using radians is necessary because key equations, such as v = rω, only hold true in radians.
  • Others question why degrees cannot be used instead of radians, seeking clarification on the preference for radians among physicists.
  • It is suggested that using radians simplifies calculations, as indicated by the equations v = rω and a = rα.
  • One participant notes that if degrees are used, additional conversion factors are required, such as v = 2πrω/360.
  • There is a discussion about whether using degrees is acceptable, but it is implied that radians are favored for ease of use.
Participants express differing views on the necessity of radians versus degrees, with some advocating for radians due to simplicity, while others question the exclusivity of this preference. The discussion remains unresolved regarding the absolute necessity of radians.
The discussion highlights the dependence on angular measurement definitions and the implications of using different units in physics equations. There are unresolved aspects regarding the conversion between degrees and radians.
shayaan_musta
Hi!
Why it is necessary to has angle in radians for SHM(Simple pendulum)?
hi shayaan_musta! :smile:
because everything works in radians
in particular, v = rω only works in radians
Thanks for reply.
But sorry for your answer.
I need a explanation that why don't we use degree instead of radians??
Why physicist agree to use radians particularly.
if we use radians, everything is easier …
v = rω
a = rα
etc
v = rω
a = rα
etc
This implies that if we use degree it is also OK. But use of radians is more easy that degree??
Right?
no … if we use degrees
v = 2πrω/360
a = 2πrα/360 :wink:
v = 2πrω/360
a = 2πrα/360 :wink:
You mean, for degree we have to use this conversion??
yup! :smile:
tiny-tim said:
yup! :smile:
OK. Thanks tiny-tim :)
  • · Replies 36 ·
