Can You Create a Circuit That Automatically Shorts 2 Cables Every Second?
  • Thread starter Thread starter roboticmehdi
    Circuit
The discussion centers around designing a circuit that can short two cables for 0.5 seconds every second, creating a pulsating current with a frequency of 1Hz. Participants explore various circuit elements and configurations to achieve this functionality, focusing on simplicity and efficiency.
  • One participant describes the desired circuit functionality, specifying the need for zero resistance for 0.5 seconds and infinite resistance for the other 0.5 seconds.
  • Another participant suggests using a BD243C NPN transistor controlled by a 555 timer to create the necessary square wave pulses.
  • A different approach is proposed involving a reed or telecom relay, which could provide a near-dead short and be driven by the 555 timer circuit.
  • One participant mentions the option of using a simple logic controller with relay outputs for more flexibility in timing adjustments, suggesting that it could be programmed easily.
Participants present multiple approaches to the problem, including the use of transistors, relays, and logic controllers. There is no consensus on a single solution, as different methods are proposed and discussed.
Participants have not fully explored the limitations or dependencies of the proposed solutions, such as the specific characteristics of the components or the implications of timing accuracy.
roboticmehdi
hi everybody. i need a circuit which will short 2 cables for 0.5 seconds every second. let me explain like this:
_______________
(+2.4v) | | (0)
in the ugly drawing above you can see two wires with a potential difference of 2.4 volts connected to a box. the box just represents the circuit that i want to make with your help.
this box must have zero resistance for 0.5 seconds and infinity resistance for 0.5 seconds. so its like a pulsating current with 1Hz across this two wires. Can you guys help me with this ? i have circuit elements like resistor, capacitor, leds, transistors(only BDX53C, BD243C, TIP41C and BDX54C), and etc... The timing doesn't have to be so strict, 0.5s+-0.05 is fine. The current that will be drawn during shorting is not high, not higher than 100ma. I need the simplest and most efficient circuit that you know :)
sorry about that drawing, it didnt come out like i wanted. here is correction:
2.4v ----------------|BOX|--------------- 0
Simplest?
Put BD243C npn transistor across those cables(collector to 2.4V side). Use a 555 timer for sending square wave pulses to base.
http://pokit.org/get/img/107e57d75a27c44c658941c60d53b2b7.jpg
Here are the values for 555 timer.
You could always drive a little reed or telecom relay if desired. Those are pretty quick and will give as close to a dead-short as you can get.
The 555 timer circuit above should be able to drive one of those without issue.
If you suspect you may need to alter timings etc and don't mind spending a few extra pounds you con get a simple logic controller with relay outputs, a basic logic programme will give you an unlimited output function with easy alterations and time scaling down to the thousands of a second.
You can get a starter kit and i promise you, you'll have programmed it within the hour even with no experience, the best thing is you can save the programme and load a new one for your next project.
9K
  • · Replies 22 ·
