Can any of you guys help to understand kinetic energy?
The discussion revolves around understanding kinetic energy, particularly in the context of two blocks connected by a spring, given an initial velocity at an angle. Participants explore the implications of kinetic energy conservation and the setup of the problem involving horizontal motion.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss whether to split velocity into components when applying kinetic energy conservation. Some question the validity of this approach, while others suggest focusing on the force component related to the initial velocity to determine spring elongation.
The discussion is ongoing, with some participants expressing confusion about the problem's setup, particularly regarding the angle of velocity and the requirement for horizontal motion. There are differing interpretations of how to approach the problem, and some guidance has been offered regarding the application of energy conservation principles.
Participants note the absence of friction and the specific conditions under which the blocks are moving, which may affect their understanding of the problem. The original poster's interpretation of the velocity direction is also under scrutiny.
suryanarayan
can any of you guys help to understand kinetic energy?
when we apply kinetic energy conservation...should we split the velocity into two components?
eg)))))
two blocks of mass m are connected by a spring and are both given a velocity v at an angle of 45 degree with the horizontal(they lie on the horizontal)
..assuming no friction is present...
what will be the maximum elongation of the spring??
i used by equating 1/2 k x2 with the initial ke of the two masses along the horizontal i.e.vcos45?is it correct?pls help me(no vertical motion)
Well energy is a scalar so it it's meaningless to split the KE into two components.
You should however find the component of the force that gave the initial velocity in order to find the elongation.
can you pls tell me how to to solve it then...or did i do it correctly?
I'm confused by the problem. How can the velocity be at a 45 degree angle with the horizontal if the masses must move only on the horizontal?
they are both given a horizontal velocity v...its given like that in the question...dont know why
In that case, I'd work it as you did.
[itex]2 \frac{1}{2} m (vcos(45°))^{2} = \frac{1}{2}k(Δx)^{2}[/itex]
