Paramaterizing a Curve: Understand Motion w/ Exponential Speed
  • Context: Undergrad
  • Thread starter Thread starter fleazo
    Curve
This discussion focuses on parameterizing a curve to represent motion along a straight line with exponential speed, specifically using the equation y=2x+1. The particle's velocity vector aligns with the vector (1, 2) and has a magnitude of e^t. The normalized velocity vector is calculated as (1/√5, 2/√5), leading to the parameterization equations r_x(t) = e^t/√5 and r_y(t) = 1 + 2e^t/√5. The integration process confirms that the parameterization correctly represents the motion along the line.
  • Understanding of parametric equations
  • Familiarity with exponential functions
  • Knowledge of vector normalization
  • Basic calculus, specifically integration and differentiation
  • Explore advanced parametric equations in calculus
  • Learn about vector calculus and its applications in motion
  • Study the properties of exponential functions in physics
  • Investigate numerical methods for parameterization of curves
Mathematicians, physics students, and anyone interested in understanding motion along curves using parametric equations and exponential speed functions.
fleazo
Hello. I had always been annoyed when dealing with parametric equations but it finally dawned on me how awesome the concept it. I want to make sure I understand things properly.
So say I have a regular straight line given by rectangular equation y=2x+1
Now I can graph this. Now say I want to consider a particle moving in motion along the path of that line. But say I want that particle to move with exponential speed, say e^t, so shouldn't I then be able to paramaterize the curve to represent that? Is there any simple algorithmic process to do so?
Thanks!
Sure, it's a simple procedure for straight lines. Your particle's velocity vector will be in line with the vector ##(1, 2)##, and will have a magnitude of ##e^t##. The normalization of ##(1, 2)## is ##(\frac{1}{\sqrt 5}, \frac{2}{\sqrt 5})##. The equation for your velocity vector will thus be $$\begin{align}v_x(t) &= \frac{e^t}{\sqrt 5}\\ \\ \\ \\ v_y(t) &= \frac{2e^t}{\sqrt 5}\end{align}$$
You integrate to get your curve (or in this case "line") parameterization, which in this case comes out identical to the velocity because of the nature of the exponential function: $$\begin{align}r_x(t) &= \frac{e^t}{\sqrt 5}\\ \\ \\ \\ r_y(t) &= \frac{2e^t}{\sqrt 5}\end{align}$$
Then you throw in a constant of integration to represent the fact that your particle doesn't go through the origin. We'll say that at ##t=0## the particle is at location ##(0, 1)##, so the equations become $$\begin{align}r_x(t) &= \frac{e^t}{\sqrt 5}\\ \\ \\ \\ r_y(t) &= 1 + \frac{2e^t}{\sqrt 5}\end{align}$$
If you differentiate those ##r_x## and ##r_y## functions you get the velocity functions. And if you take those and pop them into ##\sqrt{v_x^2 + v_y^2}## you ought to get ##e^t##; that is, unless I made a mistake somewhere, because actually I rushed while writing this. Gota run!
  • · Replies 39 ·
