Matrix word problem- Precalculas
The problem involves a shipping scenario where two factories send rice to two stores, with specific costs associated with each shipment. The goal is to determine how many loads were shipped from each factory to each store based on given constraints and costs.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss setting up equations to represent the problem using matrices. There is an emphasis on defining variables and translating the problem statement into mathematical equations. Some participants express confusion about the setup and the relationships between the variables.
Participants are actively working through the problem, identifying variables and formulating equations. There is recognition that the initial setup may be incorrect, and guidance is provided on how to derive additional equations from the problem context. The discussion reflects a collaborative effort to clarify the problem structure.
Participants note that there are constraints based on the total loads sent from each factory and used by each store, as well as the total shipping cost. There is a mention of needing an independent equation to solve the system, indicating that the current equations may not be sufficient.
thearn
Factory A and B sent rice to store 1 and 2. Factory A sent 10 loads and factory B sent 24. Store 1 used 17 loads and store 2 used 17 loads. It cost 200$ per load to ship from factory A to store 1. It cost 350$ per load to ship from factory A to store 2. It cost 300$ per load to ship from factory B to store 1. It cost 250$ per load from factory B to store 2. A tiotal of 8350$ was spent on shipping. How many loads were shipped from each factory to each store.
None
The problem that I am having is setting up the equations to create a matrice that can accurately reflect the problem.
some scribbles were
200x+350y+300z+350E=8350$
x+y+z+e=34
None
some scribbles were
x+y+z+e=34
Start by defining what your variables mean.
What do x, y z, E, and e represent?
After you do that, see if you can translate the statements in English in the problem to mathematical equations.
So I now have
200A1+350A2+300B1+250B2=8350
A1+0+B1+0=17
0+A2+0+B2=17
A1+A2+B1+B2=34
Defining the variables gives me.
A1= loads from factory A to store 1
B1= Loads from factory B to store 1
A2= Loads from factory A to store 2
B2= Loads from factory B to store 2
The answer came out with 27, 17, -10, and 0. So it's clear I set it up incorrectly.
Now that you have identified some variables, let's start translating the problem statement.
This can be translated into two equations.
One of them is
A1 + A2 = 10
Do you understand what this is saying?
If so, what other equation can we get from the sentence above?
B1 + B2 = 24
A1 + A2 = 10
yes, what it is saying is that Loads from factory B to store1 + Loads from factory B to store2 = 24 loads. Same concept with A1 + A2 = 10
None
some scribbles were
x+y+z+e=34
If A1, A2, B1, B2 are the factory-store shipments (in obvious labelling), we have
[tex]\begin{array}{l}A1+A2 = 10\\<br /> B1 + B2 = 24\\<br /> A1+B1 = 17\\<br /> A2 + B2 = 17<br /> \end{array}[/tex]
Here, you have 4 unknowns and 4 equations, but if you try to solve them you will find that you can't get a complete solution. Basically, one of the 4 equations follows from the other three, so you really have only 3 independent equations.
You need a 4th, independent, equation, and that is where the cost information comes in. So, omit one of the equations above and replace it by the cost equation---then solve.
RGV
thanks that got it done.
  • · Replies 52 ·
9K
  • · Replies 32 ·
