Physical speed of Edgerton's Trinity spool?
  • Context: Undergrad
  • Thread starter Thread starter TheFerruccio
    Physical Speed
The discussion centers around the feasibility of capturing high-speed footage of the Trinity explosion using 35mm film, specifically addressing the claimed speed of 10,600,000 frames per second and the implications of such a speed on film spool movement and duration.
  • One participant questions the validity of the claim that 3500 feet of 35mm film could be shot at 10,600,000 frames per second, suggesting that this would require the film spool to travel at an implausible speed of 894,000 mph.
  • Another participant expresses uncertainty about the high-speed capabilities of 35mm film, noting a lack of knowledge regarding such high-speed movie cameras and requests a source for the claim.
  • A different participant argues that moving film at 900,000 mph is not feasible and points out that capturing footage at 10 million frames per second would require more film than 3500 feet to cover the necessary time intervals.
  • This participant also proposes alternative filming methods, such as using a non-moving film with a rotating mirror to capture images, suggesting that this could be a more plausible approach for high-speed filming.
Participants express skepticism about the feasibility of the claimed film speed and the associated mechanics, indicating a lack of consensus on the accuracy of the original claim and the methods used for high-speed filming.
Participants highlight the need for further clarification on the technology used for high-speed filming and the assumptions behind the film's movement and duration, which remain unresolved.
TheFerruccio
I found a website which claimed that 3500 feet of 35mm film was shooting at a maximum speed of 10600000 frames per second, to catch the first millionths of a second after the trinity explosion.
I have an issue with how in the world this was done. I know that the camera exploded and the film had to be contained, but 10600000 frames per second means it traversed ~37mm 10600000 times every second. This means that the film spool must have been traveling at 894,000 mph! This would have run through the 3500 feet of spool in .0027 seconds! Am I doing these calculations wrong, or is the website wrong, or is the "huge spool of pre-tensioned 35 mm film" not quite as I am envisioning it?
This might be posting in the wrong board, so I'll try another spot. This isn't really classical physics so much as it's a general question. Feel free to delete this thread.
Do you have a link to that claim? You should be aware that 35mm film was developed as a movie camera film and was only later adapted for use in small canisters for still cameras by the Germans (initially). I have no knowledge of such high-speed movie cameras (in the claim you cited), but I'd love to see some back-up.
Well, moving film material with 900,000mph is not possible (with reasonable methods).
One odd thing: With 10 million frames per second, every millionths of a second needs some centimeters of film. Therefore, 3500 feet are a bit long to capture "the first millionths of a second".
However, I am quite sure that they did not use the regular video camera system. For example, you could use a non-moving film, and move an image over it via a rotating mirror or similar systems. This is (relatively) easy to do if you want to film a single line (instead of a 2D image), and with multiple systems you can film several lines at the same time.
  • · Replies 65 ·
14K
  • · Replies 35 ·
10K
  • · Replies 47 ·
26K
  • · Replies 18 ·
26K
